04 cobra smaller pulley tune???
A couple of comments. First, if you have a newly acquired '03/'04 Cobra you should always have the tune checked, regardless of whether the previous owner assures you that the tune is fine. It is best to not assume anything. Either go to a local dyno and have your A/F checked or use a wide band. Second, it is very smart to have the tune checked by a good tuner, and adjustments made where and if necessary. Many used Terminators come with excellent tunes. Others might not. Again, never assume anything.
As far as your numbers with the 2.80 pulley, you're right at where I'd expect you to be. With a 2.90 upper, intake, exhaust, Accufab TB/plenum and Amazon tune (excellent by the way) I made 457rwhp and 480rwtq (SAE). That was a bit on the high side of the averages. A 2.80 upper with other similar mods would likely be in the 460-470rwhp range with a similar tune.
Nov 10, 2015 11:39 AM
Sep 8, 2015 06:25 PM
