SVT Forums
Recommend me a good 700HP clutch
Old Aug 1, 2009 | 08:18 AM
renxwar's Avatar
renxwar
Default Recommend me a good 700HP clutch
Just bought a '04 Cobra, the previous owner never changed the clutch out so it may be stock. I've got a Kenne Bell 2.8 and 616rwhp. I've done some research, but every post I see generally is below 500HP, so it doesn't really apply to me.
This car might see the track 10 times during my ownership. Its going to be mostly daily driven, so my goal is a strong, long lasting clutch with stock feel. I had a Spec Stage 3 in my Z28 and I HATED it, so Spec is out. I'm thinking McLeod twin disc, but I'm not sure which one. What would also need to get replaced with the clutch? I'm used to hydraulic clutches, so I'm not sure whats up with these cables yet.
I'm just trying to get some numbers together now.. I'm in Iraq for another 6 months, so the car won't be driven.. I'd just like to get everything in order so I don't have any downtime when I get back.
Old Aug 1, 2009 | 11:49 AM
MAD SVT's Avatar
MAD SVT
McLeod Twin Disk....
/end thread
Old Aug 1, 2009 | 01:10 PM
mfj's Avatar
mfj
Banned
My spec 3+ (not the reg. stage 3) works fantastic, and I'm pushing out a lot more tq and hp than you are...
Old Aug 1, 2009 | 04:11 PM
pcs's Avatar
pcs
DD >600whp?
just change to clutch set up and resurface the flywheel. only other thing to change or just check is the plastic quadrant to see if its crack or deteriorating.
http://www.musclemustangfastfords.co...ble/index.html
Old Aug 3, 2009 | 05:54 PM
ecal533's Avatar
ecal533
I am running a Center force with a Fidianza Aluminum Flywheel (Steel Replaceable insert) with a Ford Racing Throw out and Pilot Bearing. I have no problems with my Kenne Bell, 538 RWHP and 4:10 gears. The Center Force has a patented weight technology which applys more clutch pressure as rpms spin up but the pedal feel is awesome. You don't need two feet
Old Aug 3, 2009 | 07:52 PM
MAD SVT's Avatar
MAD SVT
holy crap.... 4:10s with 538hp?? is your 60' time like 3 minutes? how the hell do you launch!?!
must be nice to spin in 4th gear though eh?
Old Aug 3, 2009 | 08:04 PM
Smokin04's Avatar
Smokin04
SPEC if you don't care about your feet.
DFX is the best single disc clutch around. PERIOD. If you must run a twin plate (which you don't need to) then go with the RST McLeod at your power level.
Old Aug 4, 2009 | 07:49 AM
ecal533's Avatar
ecal533
Thats funny. Actually it is sweet to be rolling along about 30 mile an hour or so and smash the throttle and the back end breaks loose.
But, I just had a set of 3:73 put back together in a second case that I'm putting back in. 4:10's just make you short shift every gear with that HP.
Old Aug 4, 2009 | 06:58 PM
MAD SVT's Avatar
MAD SVT
thats awesome, i just couldnt imagine having that type of gearing/blower setup, that would be intense... i have traction issues with the stock 3.55's!!
SSG Steggy
3.7L V6 Technical Discussions
Nov 5, 2015 03:09 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
RWHEELS
Sep 5, 2015 03:42 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
Emblazoned
Sep 3, 2015 10:45 PM
