SVT Forums
99 COBRA BUILD
Old Dec 25, 2009 | 12:16 AM
300Z5's Avatar
300Z5
Default 99 COBRA BUILD
im building a 99 cobra so far i have 4.6-5.0 stroker kit from eagle with h beam rods and 9.5cr dishtop pistons, my heads are port and polishd with a valve job, got ferrea stainless steele valves, comp cams valve springs and retainers, and also a pair of comp cams with .475 lift on the intake and .450 lift on the exhaust, anyone have an idea of what my dyno numbers should be around
Old Dec 25, 2009 | 10:03 AM
mfj's Avatar
mfj
Banned
What's the duration on your cams? If it was an all motor build, I definitely would have upped the compression ratio on your pistons to about 10.5:1 . You should see close to 400 rwhp on that set up, if it's set up correctly lol...
Old Dec 25, 2009 | 10:07 AM
boduke0220's Avatar
boduke0220
you building it for boost or all motor? prob not much over 300 with that setup. add some boost to that low compression and you got a good running car! yea we need more info on your cams
Old Dec 25, 2009 | 12:07 PM
300Z5's Avatar
300Z5
exhaust durration is 276 and and intake duration is 278 i was ether planing on putting a eaton or possibly two small turbos
Old Dec 25, 2009 | 02:19 PM
01snake's Avatar
01snake
i thought i heard eagle was garbage?
Old Dec 25, 2009 | 03:18 PM
mfj's Avatar
mfj
Banned
The cams you got are pretty radical NA cams and will not do well with any type of forced induction set up. Change your cams if you want to boost the car. Too much overlap...
Old Dec 26, 2009 | 02:16 AM
Fobra's Avatar
Fobra
Banned
+1 .... btw, supercharger cams generally work very well for turbo cams.
Old Dec 27, 2009 | 10:50 AM
300Z5's Avatar
300Z5
idk what to do really i already have my pistons and everything im not sure if i should just buy new pistons for a higher cr.. but iv had a few ppl tell me it was an okay setup, thanks tho
Nov 10, 2015 11:39 AM
svfetter
Oct 5, 2015 11:39 AM
88 orangepeel notch
Oct 5, 2015 09:03 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
Sparks_88
Sep 8, 2015 01:06 PM
