SVT Forums
Afco vs Fludyne
Old Feb 25, 2010 | 06:09 PM
mustangman03's Avatar
mustangman03
Default Afco vs Fludyne
Which heat exchanger is better afco or fludyne i was just curious to see what you guys thought.
Old Feb 26, 2010 | 06:43 AM
Timspony's Avatar
Timspony
SVT Section Moderator
I'm running a AFCO on the DSG...I'm sure they're about the same!!!!
I'd go with the best $$$ to my door....
Old Feb 26, 2010 | 06:54 PM
jimbob8915's Avatar
jimbob8915
What do you all think about using a motorcycle radiator for the intercooler? Can get on larger than AFCO or Fluidyne.
Old Feb 27, 2010 | 07:34 AM
Timspony's Avatar
Timspony
Both makers also have dual-pass HE!!
Old Feb 27, 2010 | 01:17 PM
Mustang3GT07's Avatar
Mustang3GT07
Why not just keep the stocker? Your not going to benefit from a aftermarket ones unless you plan on doing autox or run after run after run at the dragstrip. Go on svtp, there are a ton of threads on this subject and the stocker is good enough for the street n strip. Spend your money on something else.
Old Feb 28, 2010 | 11:00 AM
mustangman03
will do, thanks for the info guys i didnt know if it would make that big of a difference or not.
Old Feb 28, 2010 | 01:22 PM
mfj's Avatar
mfj
Banned
Go with whichever one is cheaper. I would NOT recommend keeping the stock one.
Old Feb 28, 2010 | 03:08 PM
Mustang3GT07
Why? The stock one is more then good enough unless OP has a KB or Whipple, if not the stock is fine with the eaton.
Old Feb 28, 2010 | 03:58 PM
mfj's Avatar
mfj
Banned
No offense, but are you high? KB and Whipple has much cooler IAT2 readings than an Eaton does. So why would you need the aftermarket H/E more on a supercharger with cooler temps, than on a HEATON?
Boostaddict
Lethal Performance
Nov 9, 2009 04:45 PM
Boostaddict
S197 Shelby Section
Oct 26, 2007 09:57 AM
Boostaddict
S197 Shelby Section
Oct 22, 2007 11:33 PM
Boostaddict
S197 Shelby Section
Sep 28, 2007 09:30 AM
Boostaddict
Lethal Performance
Sep 10, 2007 08:58 PM
