Upgrading to Cobra from 01 GT...Questions
Hey everyone,
I'm looking at upgrading from my 2001 GT to a 2003-2004 Cobra. I'm pretty well versed in the 4.6L 2V GT world but not so much the Terminator. What should I know about taking the plunge into the supercharged world? As far as the engine, is there much different as far as maintenance goes? What about suspension (obviously the IRS in the rear)? Any other info would be appreciated.
More specifically, I have my eye on a 2004 Cobra. It's pretty much impossible to find a completely stock Cobra but the one I'm looking at has intake, exhaust, and H&R springs. It also has 9/16 front subframe bolts, low profile rear subframe bolts in the IRS, and solid aluminum Maximum Motorsports steering rack bushings. I'm not too worried about the intake and exhaust as those are pretty self explanatory. I know suspension can be a touchy thing so what are your thoughts on the H&R springs? And are the bolt and bushing upgrades a noteworthy improvement or something I should be cautious about? It has 80k miles on it so are there any maintenance issues I should know about? How are the clutch and tranny at that mileage?
I appreciate any input from you
Thanks, Blk N Wht GT
Welcome! 80k miles is alot IMO, seeing as you can get alot of terminators with under 20k miles. Seems like it already has some good mods done to it. The first few things I would do, would be to buy the "IRS Brace", "Head Cooling Mod", and get it "Dyno Tuned". The thing I learned with these car is that also anything you do you got to get a tune. I am currently running MM Caster Camber Plates and H&R Sport Springs with the stock ISO's around. The ride is nice and an improvement over stock. I also believe the oil in the eaton needs to be changed around the 80-90k mile mark. I would also do an oil change on it as soon as you get it. I run RP and love the stuff! Goodluck and Happy modding!
Not that that is a reason to not buy the car, but means it's been driven hard...at least at the track. Just FYI
Makes sense given what Blackvenom said. Good insight
This is a must read: http://stangshiftergaskets.com/2003_2004faqs.htm
It helped me out a lot when I was deciding on what to purchase. Hope it helps you.
The 9/16 bolts is a great mod and lucky for you they are already installed..they are a PITA to instal. They pretty much stiffin the irs and help get rid of the cobra clunk...also might wanna check out svtperformance.com
read this, has tons of info for 03/04 cobras. I have owned my 03 cobra for over 4 years, upkeep is about the same as any other mustang~ nothing out of the ordinary.
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
