SVT Forums
mgw shortshift problems
Old Sep 28, 2010 | 10:00 PM
gottagetswole's Avatar
gottagetswole
Default mgw shortshift problems
96 cobra and i recently took the shifter out to change my throw out bearing.... before i took it out every gear was fine..... upon reinstalling it 5th gear and reverse are hard to get into..... it even feels like it locks it out sometime.... example usually in neutral you can move your shifter left and right.... it wont move right sometimes.... idk what i could have forgot....seemed to be pretty straight up install. but any help is appreciated
Old Sep 30, 2010 | 03:53 AM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
did you replace the fluid that spilled out when you took the trans out? Is it at the correct level? When you pulled the shifter base off did the little plastic cup come out with it? If you lose that it wont feel very well
Old Oct 3, 2010 | 02:25 PM
gottagetswole
yes replaced the tranny fluid and put 3.6 quarts and the bushing.... so idk whats goin
Old Oct 3, 2010 | 08:04 PM
gottagetswole
just figured out the problem..... ashamed to say when i took the shifter out the first time i couldnt find the bushing so i just replaced it but it was sitting at the bottom of the shifter making it hard to get into gears =(
Old Oct 4, 2010 | 03:49 PM
945LSTANG's Avatar
945LSTANG
so you had two bushings on there? lol
at least the problems fixed.
Old Oct 4, 2010 | 08:51 PM
gottagetswole
well it poped out the first time i took the shifter out so it was laying to the side making it impossible to put it in gear
Old Jun 17, 2021 | 12:30 AM
Bobby76's Avatar
Bobby76
Default Stiff short shift after fluid change
I am having the same problem with my shifter I have to force it into first or second and when is a neutral it just wants to go to the right instead of in the middle I read where are you put two bushes in there are you talking about the cup at the bottom of the shifter because mines doing the same thing that your was doing
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
