SVT Forums
Engine Shaking...Help!
Old Oct 19, 2010 | 04:00 PM
Vnumuss's Avatar
Vnumuss
Default Engine Shaking...Help!
So my friends 95 Cobra(5.0) engine shakes pretty bad @ idle, but as soon as you give it a little gas it goes away like there's not a problem. It idles a little high(a little over 1000rpms), until you start driving it around, then the rpms sit where they are suppost to sit, another weird thing is that when the engine is shaking @ idle, if you turn the a/c on, the shaking goes completely away...does anyone have any idea of what the problem is? anyhelp is great...thanks!
Old Oct 20, 2010 | 05:40 AM
Blackvenom01's Avatar
Blackvenom01
sounds like motor mount and the idle is just the correct rpm to make it shake the best when you turn the ac on puts a load on the motor so changes the rpm just enough to stop
Old Oct 20, 2010 | 05:47 AM
uberstang1's Avatar
uberstang1
Chupacabra
+1 check the motor mounts.
Old Oct 20, 2010 | 05:59 AM
Timspony's Avatar
Timspony
SVT Section Moderator
...I was thinking the same thing!
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
rksnow1
Sep 14, 2015 08:46 PM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
