SVT Forums
Cobra clutch ticking!!!!!!
Old Dec 22, 2010 | 07:06 AM
PurpleIcedGT's Avatar
PurpleIcedGT
Originally Posted by Bladerunner
Sounds to me like your throwout bearing is failing.
Upgrade to a Centerforce Dual Friction clutch!
Do us all a favor and tell us WHY the OP should upgrade an entire clutch system for a failing TOB. Why is that? a Ford Racing TOB off Lethal Performance is something around 67 bucks....a "centerforce dual friction clutch" which you so appropriately mention in every single one of your spamming posts is what, 450 doll-hairs? Should he swap out his suspension for an "Eibach Pro-kit" and swap out his gears for 3.73s too? Theres a big difference between throwing an idea/opinion out there and pointing people down the wrong path.
OP - Don't listen to this clueless @$$hole. I experienced the same problem with a ticking clutch back in September of this year. It was indeed my TOB that literally incinerated. I bought a FRPP TOB off of Lethal Performance (60-70 bucks, I can't remember exactly how much). Feel free to check out my thread titled "This Clutch is a B*tch". UBER helped me through the entire process and HUGE PROPS goes out to Uber, someone who actually knows these cars. My clutch was not slipping, therefore, I didn't replace the clutch. I threw the new TOB in there and it has been perfect since. Best of luck getting it sorted out man!
Old Dec 22, 2010 | 07:22 AM
mance01cobra's Avatar
mance01cobra
Originally Posted by Timspony
Throw out bearing?
Old Dec 22, 2010 | 08:46 AM
djervin's Avatar
djervin
Well, now that it has been beaten to death and I am a little late. Sounds like your TOB. I just replaced mine a couple of hundred miles ago because that along with the retainer sleeve was destroyed. I purchased the FRPP TOB and Lethal retainer sleeve for $167 and did not replace the clutch, there was no reason, it was not slipping and only had 16k miles on it. Besides, these cars are not that difficult to work on, dropping the trans was a lot easier than I though it was going to be....
Old Dec 22, 2010 | 11:09 PM
1fast5089's Avatar
1fast5089
Thanks every one for your post the guy I bought the car from said it wad a napa cluch so I had pland on swapping that out any ways but for now a TOB seems thr easyist way thanks
Old Dec 23, 2010 | 10:09 AM
Blackvenom01's Avatar
Blackvenom01
haha i swear hes a centerforce dealer lol... but my advice is to get the frpp one cause alot of companys make some cheap ones that will blow apart in a few hundred miles!! as far as clutchs dont overdue the clutch you dont need to get one that rated for 500hp for a 300hp car...dual friction like my spec clutch is nice if you have some extreme power but for normal stock cars its not needed....i wouldnt expect a napa clutch to last all that long lol but it works for the time being i guess lol
Old Dec 23, 2010 | 05:04 PM
945LSTANG's Avatar
945LSTANG
amen purp.
Old Dec 26, 2010 | 01:17 PM
uberstang1's Avatar
uberstang1
Chupacabra
I would avoid the Spec clutches like the plauge my Spec Stage 2 clutch
failed on me in 5K so screw Spec.
Since the guy above will have to take everything apart just to replace
a simple throwout bearing he mite as well install a better clutch like
the Centerforce Dual Friction clutch.I Know a few guys that have
smoked the FRPP Cobra clutch with 200 rwhp lol.
This theory would work if it was a cheaper part, but replace a 400+$ part just cause it is apart and isn't broke is a waste.
Old Dec 26, 2010 | 03:13 PM
BlewByYou's Avatar
BlewByYou
Throw out bearing for sher man. Thay go bad alot.
Thunderball
15
Nov 22, 2015 11:49 PM
88 orangepeel notch
Oct 5, 2015 09:03 AM
junior04
Sep 28, 2015 10:53 AM
Sixer4Life
Sep 28, 2015 07:05 AM
MacSerio
Sep 27, 2015 01:05 PM
