SVT Forums
1999 cobra knocking
Old Feb 3, 2011 | 04:26 PM
jerry.shockley's Avatar
jerry.shockley
Default 1999 cobra knocking
i have a 1999 cobra that has a knock on the passanger side of the engine.....it only does it when you let off the gass....it still runs great and sounds good just whenever you let off the gass it has a knock that last for about a second....any help in what direction to look would be great or if you had one that did this????what did you find out
Old Feb 3, 2011 | 04:52 PM
Rokgtar's Avatar
Rokgtar
I had a similar knock with my 97 Cobra - turned out to be a spun #4 rod bearing. Thats on the passenger side. I figured it out initially by disconnecting the plug wire on each cylinder on the passenger side, then starting it up... the noise went away on #4. The teardown confirmed my fears.
Old Feb 3, 2011 | 05:13 PM
jerry.shockley
going to go try that and see what happens
Old Feb 3, 2011 | 05:44 PM
jerry.shockley
just trided that didn't do anything but when i got done it made a clank then died....now it won't start.....could it be the timing
Old Feb 7, 2011 | 02:37 PM
xxlcobra's Avatar
xxlcobra
Miles on her?
________
Nexium pregnancy
Old Feb 8, 2011 | 12:33 AM
jerry.shockley
76 thousand
Nov 10, 2015 11:39 AM
88 orangepeel notch
Oct 5, 2015 09:03 AM
Dan04COBRA
Sep 30, 2015 11:46 AM
rdog69t
SVT Forums
Sep 13, 2015 06:16 PM
Sparks_88
Sep 8, 2015 01:06 PM
