SVT Forums
1996 Cobra engine problems
Old Feb 17, 2011 | 03:22 PM
tony28's Avatar
tony28
Default 1996 Cobra engine problems
I have a 96 cobra and its been giving me engine codes p0411 and p1143. i looked online and cant find those codes as ford obd II codes. P1143 - Heated Oxygen Sensor 1 Lean Shift Monitoring Bank 1, does that mean i just need a new o2 sensor in that bank? and P0411 - Secondary Air Injection System Incorrect Flow Detected, new smog/air pump? whats the best course of action here? car still runs fine no hesitation or loss of power. just the check engine light.
Old Feb 17, 2011 | 05:26 PM
Blackvenom01's Avatar
Blackvenom01
ya dude i would just replace both front O2 sensors easy fix!! as far as the other code idk never had that code on any job before
Old Feb 17, 2011 | 07:34 PM
tony28's Avatar
tony28
yeah thats too easy, ive read that its common for water to get into the air pump and cause problems, other than the air pump itself could there be anything else that could cause the air pump to not function properly? perhaps a valve or solenoid or somthing?
Old Feb 18, 2011 | 05:37 AM
Blackvenom01
hmm like i said im not completely sure cause nobody i know has ever has this code but i feel like the reason for that is they all deleted there smog crap...there very well known for going bad and most ppl just delete it!! ive just never seen the code for it
Old Feb 18, 2011 | 07:47 AM
tony28's Avatar
tony28
ok, that sounds like a better idea just delete it all together. i had an 87 GT that went through 3 smog pumps. its ridiculous. thanks for the advice.
Old Feb 22, 2011 | 06:57 AM
uberstang1's Avatar
uberstang1
Chupacabra
I delelted my air pump, "secondary air injection" as its know. Cleans up alot of crap under the hook including all the plumbing and check valves that attach to the manifolds.
djbigskrilla
Sep 20, 2022 01:04 AM
Diode Dynamics
28
May 26, 2022 12:02 PM
Nexuia
Aug 23, 2015 11:30 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
HIS S-197
Aug 10, 2015 05:47 PM
