SVT Forums
Tires an alignment question
Old Feb 23, 2011 | 06:25 AM
slidai's Avatar
slidai
Default Tires an alignment question
So, i am taking delivery of a 2003 cobra with around 600 hp here in the next week or so. I have a question about tires and alignment.
I want to add bigger tires on the back. Something like 330/30/18. I know i need to add bigger rims, something like 18x9.5 or 18x10.But i am not sure about the exact size rim. Does anyone know what the largest tire and rim you can put on the car without having to roll the fenders or add different bolts?
Since the rear tires are going to be much larger then the front, i was wondering about the alignment. Since i normally do a modified-x when rotating, would i just move the tires side to side and would this really shorten the life of the tires or would it not really matter?
What tire size and larger rims do you all use.
Old Feb 23, 2011 | 07:54 AM
TRUEBLUE3934's Avatar
TRUEBLUE3934
WOW!
I don't know what the largest size tire that will fit the IRS Cobras without rolling fenders, but I do know that you will need/want at least a 10.5" or maybe even 11" wide wheel for a 330mm wide tire.
Old Feb 23, 2011 | 09:35 AM
ttoney's Avatar
ttoney
You need to run low profile IRS Bolts and possibly spacers to go super wide.
http://www.lethalperformance.com/03-...olts-2-p-13056
Here is a decent thread on wide tires on Terminator.
http://www.svtperformance.com/forums...ever-used.html
Old Feb 23, 2011 | 11:10 AM
kbraklr's Avatar
kbraklr
Banned
You can't go any higher than a 305 without having any modifications.
Old Feb 23, 2011 | 11:11 AM
Timspony's Avatar
Timspony
SVT Section Moderator
...I've seen 335's on a 10.5" - 17" wheel ...Looked good!!!
If you're lowered, you might have to roll the lips...and get an alignment to the factory specs!
mtgldr
Feb 3, 2024 09:00 PM
mmarsh3014
Wheels & Tires
Oct 20, 2015 09:08 AM
Sep 8, 2015 11:50 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
