I just ordered a new 2.9 whipple and am trying to peice together the rest of the junk ill be needing. My question is are 60s going to be enough or should i get some 80s instead? I plan to run around 18lbs of boost somwhere in the 650hp range im guessing. I dont plan on upping the boost anymore than that on this car so with that said.....are 60s going to flow enough?
still has its limits with a BAP...you can use one and it will work great till you burnt out your fuel pump cause youll be running it at like 110% of it capacity....thats where im stuck at is gettin a returnstyle fuel system and bigger pumps and im all maxed out on my fuel system at 650hp just a thought man
