99 cobra N/A build questions
Hey guys I got my cobra at the beginning of this year and i think its time to give it a little more kick I was wondering what you guys would suggest for a N/A build to get about 400-425HP out of the stock engine any tips are appreciated
well thats gonna be tough you basically will have to do a complete engine overhaul and turn it in a all motor car...in the end would be just cheaper to spend 2k and get a centri or use eaton
as far a started mods intake exhaust gears tune and it will make a considerable difference!
another cheap way to add some power is a nice wet or dry shot those come pretty cheap from American muscle
well i want to stay away from nitrous never really been into that whole thing but i was talking to a friend he told me he could forge my internals for around $3k if i was going to force induct it but thats 3k on top of the cost for a super charger i just want to see which route would be best bang for my buck but as it stands now i have the bassani x-pipe already which intake would you recommend i mean it comes with a K&N i figured that was a pretty decent intake gears i was looking at 3.73's since it'll mainly be a daily driver
well what would be an ideal supercharger set up for this application i was looking into the kenne bell 2.1 but i am lost when it comes to the supporting mods to handle the boost i know the car stock should be able to hold up but i just want it to be as stable as possible without being through the roof expensive
yes you dont necessarily need to build your motor to throw some boost on it...as long as you have a great tune and keep it around 9psi youll get alot more power and still have a reliable DD...there are many cheap options...you could get a used eaton from a termi and build it you could get a centrifugal sc like vortech or paxton...you could get a twin screw like whipple or KB....a twin screw is constant power and instant boost...a centrifugal builds boost as you go up the rpms
supporting mods arent that much new injectors KB boost a pump for more fuel and a couple small things they make complete kits and theres also threads on how to build your own kit
hey guys quick question here i was looking at the bbk TB in 62mm and 65mm twin blades on americanmuscle.com and trying to compare those with the 60mm accufab which one of the three TB's would you recommend with a JLT performance ram air intake
