SVT Forums
Starting Problems
Old Sep 22, 2011 | 02:45 PM
nodnarb85's Avatar
nodnarb85
Default Starting Problems
I have a 98 cobra and am having annoying starting issues. Every night it has to be put on a trickle charger to start in the morning. The battery and alternator were replaced trying to fix the problem. I'm not sure if it's the starter or not. Last night I couldnt get it to start even with a jump. I was able to push start it though. There has to be something draining the battery. I took a video of static noises coming from the speakers when the car is off. If I unplug the battery it stays charged. In the video you can hear me opening and closing the doors as well as the static noise. I have no idea where it's coming from or what's causing it. Hopefully you can help.
http://www.youtube.com/watch?v=8S6QBpZJX30
Old Sep 22, 2011 | 02:49 PM
tightdogal's Avatar
tightdogal
When you turn the key, do the accessories come on and does it make a "clicking" noise while you're trying to start the engine? If so, that's a starter issue.
If it is the starter, here's a tip. Get someone to have the hood open and tap the starter with a wooden stick while you're turning the key to start the car. I've done this several times.
Old Sep 22, 2011 | 02:59 PM
nodnarb85's Avatar
nodnarb85
Yes it does click and I know about the starter trick. I'm going to take it off and have it bench tested. The noise is what I'm more concerned about because I think that is what is draining the battery.
djbigskrilla
Sep 20, 2022 01:04 AM
jjwinel78
Aug 17, 2015 03:34 PM
cvarner131
Aug 17, 2015 07:38 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
Pain.
Aug 7, 2015 10:48 PM
