SVT Forums
Keyless Entry
Old Jan 19, 2004 | 10:33 PM
mustangdave357's Avatar
mustangdave357
Default Keyless Entry
Did a 95 Cobra come with Keyless entry, I just bought one and it doesnt have it but I am not the second owner. Could have gotten lost along the way. Thanks, Dave
Old Jan 19, 2004 | 10:40 PM
BLKSTANG9879's Avatar
BLKSTANG9879
It should have it. My sister has a 95 and hers has a keyless entry.
Old Jan 20, 2004 | 01:09 AM
mustangdave357
So can I just buy any keyless entry remote from E bay for a mustang that was a 1995 and it should work if I have it? Not every keyless entry remote would unlock every mustang I would think. That would be a car thiefs dream. So basically will any remote for a mustang work or do I need a specific one?
Old Jan 21, 2004 | 05:09 PM
whitelightning's Avatar
whitelightning
You need the keyless remote for that year (I think 94-98 are all the same) If you look on e-bay you can find them new! You can program up to 4 keyless remotes at one time. If you search e-bay most of the units say what cars they will work on and they should come with programming instructions. I have a 95 and I bought 2 remots off e-bay as the previous owner lost mine. The keyless entry unit is in the trunk area on the drivers side. Remove the carpet material and there is a mounting bracket that holds the keyless entry unit (mounted on back) and the anti-theft unit (mounted on front. To program the keyless entry you have to put the key in the ignition and turn it on, but don't start car. In the trunk by the unit you will find a harness that has 2 pins, short those together and the doors will lock then unlock, that tells you that it is in program mode, then you push any button on the remote and the doors will lock and unlock again to let you know the remote was programmed, then you hit a button on any other remotes you are programming and the doors will lock and unlock again. Turn the key off and you are done! It takes only a couple minutes and this will delete any previous remotes and program the new ones. Hope this helps!!
dubarado
Dec 23, 2015 01:16 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Sep 8, 2015 11:50 AM
ccwebb
Aug 11, 2015 06:47 PM
