HELP
Old Mar 4, 2007 | 11:56 PM
code3GT's Avatar
code3GT
Mustang Nazi
Default HELP
Brian,
What would it entail to convert to a return style fuel system on the Bucket? I am thinking of switching to a 5 gallon fuel cell to shed a little more weight. THANKS
Mitch
Old Mar 7, 2007 | 01:53 AM
Texas_Hot_Rods's Avatar
Texas_Hot_Rods
Default RE: HELP
Code,
it's pretty simple. You need a cell, a pump & by pass regulator, and then the lines and fittings. We have a complete Aeromotive kit available that is stainless braided supply & return lines, all fittings, adel clips, and the fuel rails with 2 different pumps available depending on HP/TQ needs. I will try to post up some pricing tomorrow and some pics of the last couple we installed. You will also need to have the car re-tuned with the Fuel Pump Type changed as well as the Fuel Pump Switch changed and depending on the software, SCT, Diablo, etc... you may need to tweak a couple more items like the Purge Canister Bypass setttings as well as the Fuel Pressure Sensor Rail Switch. I can send you the tune from my twin turbo stang just to compare the fuel setting if your tuner needs. (or you can send us the bucket for a THR tune ! )
Old Mar 7, 2007 | 09:47 PM
code3GT's Avatar
code3GT
Mustang Nazi
Default RE: HELP
ORIGINAL: Texas_Hot_Rods
Code,
Brian, I have CPR billet high flow rail now, so would I have to change? Also, you will be tuning the Bucket next time I need a tune.
Old Mar 8, 2007 | 12:48 AM
Texas_Hot_Rods
Default RE: HELP
the only difference off hand might be the fitting they use as think they are NPT rather than AN.
