Used - 4 OEM wheels with snow tires mounted and balanced
For SaleWheels and Tires/Axles
Description:
4 used Mustang OEM rims with snow tires mounted on them. Used only in winter. Had separate set of rims for summer tires. There is at least another another winter season left in these I believe.
These wheels are plasti-dipped silver wheels. I wanted the flat black look. The protective decorative coating is readily removable with elbow grease or power washer as you can see in one of the closeup photos above where some of the coating has rubbed off.
I will remove the coating if that is what you prefer.
