6R80 to mt82 swap
Old 07-16-2017, 07:25 PM
Csa0890
Csa0890's Avatar
Default 6R80 to mt82 swap
I have a 2017 ecoboost automatic and would like to find someone that is wanting to swap transmissions.
Csa0890 is offline
Old 07-16-2017, 09:19 PM
fourdegrees11
fourdegrees11's Avatar
Might be more cost effective to trade your whole car for a manual version...
fourdegrees11 is offline
Old 07-17-2017, 01:19 AM
imp
imp's Avatar
Jeez! I'm so far behind the times, I don't even know WTH you guys are talking about, except maybe it's transmissions?? imp
imp is offline
Old 07-17-2017, 06:37 AM
Csa0890
Csa0890's Avatar
Considering about the only cost would be shipping, no it would not be more cost effective...
Csa0890 is offline
Old 07-20-2017, 01:55 PM
Derf00
Gentleman's Relish
Derf00's Avatar
You'd also have to swap PCMs, pedal boxes, shifter mechanisms, supporting hardware and possibly even wiring harneses unless you can find a shop willing to provide that level of programming for the PCM.
Newer Autos are all electronic so to simply swap the tranny also involves turning off all the auto routines in the PCM (most shops can't or won't do that).
Ford will only program a PCM to match the car's VIN. If you try to have them program your Auto PCM to a manual version they won't do it because your VIN number shows it was programmed from the factory as an Auto so the only programs available to them for your car VIN are auto programs.
So while there's explicit cost as in $ there's also implied cost of time and energy in performing the swap and figuring out all the potential and real problems of the swap.
I've you've got all that other stuff already figured out or have the time and resources, then yeah, it might be cost effective for you.
Derf00 is offline
Old 07-25-2017, 07:31 PM
Csa0890
Csa0890's Avatar
Yeah im aware of whats involved. This isnt my first rodeo. Also if you swap entire ecus there is no need in programming anything except maybe axle ratios.
Transmission
ecu
Wiring harness
Pedals
Master cylinder
Clutch lines
Flywheel
pressure plate
flexplate
Slave cylinder
Csa0890 is offline
Old 07-25-2017, 07:34 PM
Csa0890
Csa0890's Avatar
And shifter assembly and gauge cluster.
Csa0890 is offline
