Road & Track, Here are the official 2015 Ford Mustang power and weight numbers
Old 08-20-2014, 06:20 PM
  #21
JIM5.0
JIM5.0's Avatar
Originally Posted by pascal
You get HP mostly in the heads through good flow and good cams so that means the intake has to match as well.
Jack Roush used to build us a 650hp mill from the 5.0 Cammer and it was all naturally aspirated.
Now, of course it was a race engine and it would have to be tune down a bit to be streetable and most importantly, reliable.
I believe it's possible to get 500/550 streetable horsies from the Coyote if someone was willing to engineer it.
The problem is, the market is more prone to boosting rather than getting most gains out of a NA set up.
I totally agree. These guys in this link hit 625BHP from a naturally aspirated Coyote and still was holding onto its torque like white on rice.
In the vid, the modders also explained that theyw ere able to retain a good amount of low and mid RPM torque because of the TiVCT.
Since the S550 will have mid-phase long TiVCT, I am curious just how much more low and mid RPM torque can be gained.
JIM5.0 is offline
Old 08-20-2014, 07:11 PM
  #22
jz78817
jz78817's Avatar
For making more than 400ft-lbf crank torque from the Coyote with no nitrous or forced induction, it can be done.
show me where I said it was impossible.
jz78817 is offline
Old 08-20-2014, 07:14 PM
  #23
99GTvert
is my username.
99GTvert's Avatar
pull starts @ 2:25....sounds very good, like a nascar.
99GTvert is offline
Old 08-21-2014, 06:20 AM
  #24
JIM5.0
JIM5.0's Avatar
I never said you said it was impossible. I only said it is possible and never tried to say that you said anything.
I remember your exact words were:
there are limits to what you can get from a naturally aspirated engine of a given displacement. Coyote is pretty much limited to about 400 lbf-ft without forced induction. making bigger hp numbers means they'd have to push the torque peak higher in the RPM band, at the cost of low- and mid-range performance.
To a point, yes, for a given displacement, there is an absolute limit to what you can get out of it naturally aspirated no matter what you technology you throw at it. That is physics.
However, our 5.0 engines still have a whole lot more in them and are still a ways off from maximum tpossible torque production for their 302ci displacements.
The 5.0L is a great compromise between lower displacement V8 (actually, more a mid-displacement V8) producing decent torque and great BHP.
And the naturally aspirated Coyote isn't done yet; Ford still hasn't implemented direct injection. Will DI give more torque and BHP throughout all RPMs? Most likely, yes; especially if Ford can tune the DI spray patterns to work reliably, cleanly, and efficiently for 12:1 CR or more.
Even if DI doesn't give any more BHP than 435BHP or only adds a miniscule amount more of BHP, the area under most of torque curve will be increased, and also hopefully broadened. So that "pretty much limited to 400ft-lbf" limit is not true.
If rumors are true about a project "Voodoo," the GT350 will be producing in excess of what the Aluminator XS produces both in the torque and BHP departments while remaining naturally aspirated.
JIM5.0 is offline
Diode Dynamics
28
05-26-2022 12:02 PM
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
08-10-2015 01:44 PM
tmdm
08-07-2015 10:24 PM
Quick Reply: Road & Track, Here are the official 2015 Ford Mustang power and weight numbers
