help needed! Electrical issue after putting battery in wrong
Old 02-10-2018, 11:14 AM
Xhead121
Xhead121's Avatar
Default help needed! Electrical issue after putting battery in wrong
Ok so my dumb cousin accidentally put the battery on backwards and now the battery is not charging aka (the alternator is not powering up) I checked the cable that runs to the alternator and the alternator and they're both good. But I found that there is no power going to it from the post on the fuse box. I checked the manual and it says "m case fuses" but I'm not sure what that is and where they are because they're not visible that's for sure. I have a 2015 mustang gt FYI
Xhead121 is offline
Old 02-18-2018, 08:51 AM
wildbadbill
wildbadbill's Avatar
is the engine running?
Dumb *** did the same to my friend few years back-the total was $3000 including blown computer
Hope it's not the case.
wildbadbill is offline
Old 02-18-2018, 11:07 AM
Xhead121
Xhead121's Avatar
Default Problem fixed
it was a blown main fuse, i had to order it from ford. $20 bucks and $70 installation...
Xhead121 is offline
Old 02-18-2018, 11:30 AM
barstowpo
barstowpo's Avatar
There may be a fusible link in the main wire. Check for a place where the wire feels more floppy than the rest of the harness. Also look for signs of melting. Hopefully the alternator isn't cooked too.
barstowpo is offline
Old 03-08-2018, 05:23 AM
jz78817
jz78817's Avatar
I don't think anyone does fusible links anymore. not since the '90s when everyone moved to power distribution boxes.
jz78817 is offline
Old 03-08-2018, 11:47 PM
imp
imp's Avatar
Ford continues to use fusible links to this day. What makes you think power distribution boxes eliminate the need for adequate circuit protection? imp
imp is offline
Old 03-11-2018, 06:52 AM
jz78817
jz78817's Avatar
where the f*** did I say that? PDBs incorporate FUSES which are CIRCUIT PROTECTION.
a plug-in/screw in fuse is a lot easier to replace than a fusible link.
jz78817 is offline
Old 03-11-2018, 02:12 PM
08'MustangDude
Banned
08'MustangDude's Avatar
Simply making your statement about no one using fusible links since the '90s untrue, nothing more, nothing less.
08'MustangDude is offline
Old 03-11-2018, 11:07 PM
imp
imp's Avatar
You said:
Interesting dialog here! Especially since it involves me! I'll add clarification: Everyone started using Power Distribution Boxes:: Just another fuse block, with anticipated high-current protection need, much of which feeds "sub-fuses" which are relegated to specific use. No more "one fuse feeds" parking lights, turn signals, radio, horn, etc. My 1955 Merc had 7 fuses and a circuit breaker. My 2004 Explorer has around a hundred!
Fuse Links: Only expected to "blow" under very unusual overload circumstances, like connecting things BACKWARDS. Around 1990, Ford Mustangs used something like 6 or 7 fusibles, maybe 8. My Explorer has 3; all are there to protect the alternator. Fusibles provide a cheaper-than-replaceable-fuse means of Engineers covering their a$$es to avoid lawsuits. Trouble arises when some guy totally wraps tons of pretty tape and **** around those fusibles, thus ensuring possibility of fire. They DO get blisteringly hot before "blowing". imp
imp is offline
Old 03-12-2018, 03:08 AM
08'MustangDude
Banned
Quick Reply: help needed! Electrical issue after putting battery in wrong
