The Racers Bench Is the track just too much for you? Want to know what will beat what? Talk about it here!!
Altitude Correction
Old Aug 12, 2009 | 11:23 AM
  #21
S8ER01Z's Avatar
S8ER01Z
Originally Posted by Riptide
FWIW even the NHRA doesn't take a DA corrected time for a record.
They do however take an altitude only corrected time. You can see the tables in the link on the OP.
EXACTLY..I was going to post up but you beat me to it.
Old Aug 12, 2009 | 12:00 PM
  #22
67mustang302's Avatar
67mustang302
Talk about a topic that's been bludgeoned to death...
The biggest point of the DA correction is comparison. When you have 2 cars running at 2 tracks in 2 different conditions in 2 different parts of the country at 2 different times, there's NO WAY you could have any type of a remotely valid comparison without eliminating some of the variables. The DA correction helps to eliminate those variables(primarily weather and altitude) and then mainly leaves driving and track prep as variables. It allows for a more valid comparison between the performance of 2 vehicles but is still only a ballpark figure.
Even then the variable you can NOT eliminate(not without testing it and coming up with another calculation, which would be specific to each vehicle) is how each car would handle increased power as it relates to traction. You could theoretically have 1 car "correct" to a faster ET/MPH but react worse in terms of suspension, and the slower "corrected" car may in reality be faster in terms of real world ET.
Old Aug 12, 2009 | 12:12 PM
  #23
JD1969's Avatar
JD1969
Pro. B.S. caller outer
lol are some of you guys sharing the same bong or what??
I think the point here is being missed. The NHRA themselves told me that the altitude corrected time, from an appropriate track such as mine, counts for records. So I'm sorry AZ I'm going to have to go with the NHRA on this one brah.
The point of these correction factors is to give you the time that you would have run if your track had been at sea level. All else being equal. These corrections are good enough for them to take seriously so they should be good enough for you too. Unless you think you're more of an authority on the subject than they are?
Ofcourse track prep for instance could be different if I ran at a DIFFERENT track that same day at sea level. That is completely beside the point.
I don't think Mishri or I or anyone else on here has ever to my knowledge done a corrected time and presented it as an actual. But it is a bit tiresome to hear the naysayers pop in and get after you for simply quoting a corrected time in context.
What you are failing to understand is that the NHRA started using correction for some very specific classes. You don't see it used in T/F or P/S now do you? It was never meant to be used by anything other than those classes. No other racing organization uses correction (NMRA, NMCA, hell I don't think IHRA uses it). If you have been around Super Stock or Super Comp racing you would understand the concept. In order to level the field a little bit those INDEX (key part) classes use it. Yes I agree it can be used to get a rough idea of what a car might run in better conditions. The part I find funny is that people who live at high elevations are always the ones crying the loudest about it. Run your car, post the DA so that intelligent people can draw conclusions but posting a a corrected time is lame. Sorry.
Old Aug 12, 2009 | 01:18 PM
  #24
72MachOne99GT's Avatar
72MachOne99GT
2010 Blue Ball Award Recipient
Does anyone know how to do it backwards?
I did not click the link so I'm not sure how specific the table gets, but if I ran a 13.6@100 with XXX DA *good like it was that night*, could I then convert it to say, a time up in the mountians?
If so, I'll run around with a DA Uncorrected ET in my signature to make people feel better.
Old Aug 12, 2009 | 01:39 PM
  #25
Bmr4life's Avatar
Bmr4life
LOL, I love that idea.
Old Aug 12, 2009 | 01:52 PM
  #26
98LS1's Avatar
98LS1
Originally Posted by chain1
That's simply not true. At the lower altitude you are obviously putting down more power. Who's to say you would get the same traction as you did with the reduced power??
Also, based on this logic, why even run races. You could just look at engine configuration and altitude and then bust out the calculators and figure out the winner without even cranking the engine.
Head of nail meets hammer.
Old Aug 12, 2009 | 01:56 PM
  #27
Bmr4life's Avatar
Bmr4life
Yeah, grampa_stang said similar earlier.
Old Aug 12, 2009 | 02:21 PM
  #28
2000AZ5.0GT's Avatar
2000AZ5.0GT
the problem is it's not what 'WOULD' have happened, it's what 'COULD' have happened. It's saying that all things being the best they can possibly be, that's what your car is capable of in a "best possible run" scenario.
you can't claim "what could be" as "what is"
Old Aug 12, 2009 | 03:48 PM
  #29
AmericanSpeed's Avatar
AmericanSpeed
Its all about the 60' time, like grandpastang and chain1 said. Especially when running on street tires when its really hit or miss. I wonder how the correction affects 60' time (does it lower that?).
Example: Say you are running on street tires making 250 hp at high alt, and pull a 1.90 60' time. At a sea level correction you are making 350+ hp, does the correction bring down your 60' time to 1.6-1.7 or something (highly unlikely joe smoe is pulling that 60' on street tires)? The correction factor does not know the capabilities of the tires (or the driver).
I guess it would be helpful to know the correction factor formula and how it effects everything (maybe the website shows it, I didnt check).
I think this is where everyone gets a little untrusting of corrected times.
Like JD said, intelligent people will understand that you are running in some crap conditions.
Old Aug 12, 2009 | 05:04 PM
  #30
S8ER01Z's Avatar
S8ER01Z
It takes some time (like figuring out crank HP when you know the DTL % and rwhp of a car)...just crank the numbers by hand until you match.
