The Racers Bench Is the track just too much for you? Want to know what will beat what? Talk about it here!!
Need Advice
Old Apr 18, 2010 | 04:50 PM
BKAT's Avatar
BKAT
Default Need Advice
Well I'm getting my rear finally done tomorrow....I went with:
-FRPP 410's
-FRPP Track Loc Diff
-Moser 31 Spline Axles
-Motive bearing Kit
Also going to be running on Mickey Thompson 275/40/17 ET Streets.....
Want to know what psi is good for the tires, and where should I launch around?
Thanks guys...
Old Apr 18, 2010 | 05:03 PM
sonicx's Avatar
sonicx
speed'n
There is no 'golden' tire pressure because The optimal setting depends on the individual driver and his preferences.
HERE is a FORUMLA I use:
(Vehicle Weight in lb/100) + 2 psi at heavier end + 2 psi all around if suspension and alignment are stock.
edit: Then i'd say 25000rpss (street) and 5000rpms (track)
Omgitsa88Stang
Oct 5, 2015 07:33 AM
Shadow7874
Sep 24, 2015 09:06 PM
2k232
Sep 16, 2015 10:28 AM
EASTIDEE123
Sep 15, 2015 11:08 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
