The Racers Bench Is the track just too much for you? Want to know what will beat what? Talk about it here!!
Traction Control
Old Apr 28, 2010 | 12:20 PM
Riptide's Avatar
Riptide
Default Traction Control
Query. How come noone ever seems to use this?
I compared my best attempt with TC and without.
They were within a single tenth. And my attempt without TC? I had 4.10 gears installed at the time. Not so on the attempt with TC on.
Old Apr 28, 2010 | 12:29 PM
Stone629's Avatar
Stone629
What was your 60' with and without the TC on. It doesn't effect mine much if I'm only launching at 3k and not powershifting, but with 5k RPM launches and powershifts, the TC becomes very intrusive on my car.
Old Apr 28, 2010 | 01:10 PM
Riptide's Avatar
Riptide
WITH TC
14.08 ET
101.29 MPH
2.23 60'
WITHOUT TC
13.96 ET
100.14 MPH
2.08 60'
The attempt without TC had an upgraded set of gears and taller/wider tires.
Old Apr 28, 2010 | 02:15 PM
Stone629's Avatar
Stone629
That difference in your 60' is huge. If you had of driven exactly the same way on both runs, your run with the 2.0 60' theoretically should've been more like a 13.6-13.7.
Old Apr 28, 2010 | 02:55 PM
67mustang302's Avatar
67mustang302
It depends on the TC. Most of the systems on American cars suck, and pull all kinds of timing and make the car run like a turd. The more advanced European systems actually limit how far the throttle opens to provide the most amount of power at the wheels that can be used effectively. I saw a guy at the strip once with the new BMW M3 with the 4.0 V8, launching with his TC on he just revved up to like 6,000-7,000rpm and let the clutch go....the TC would limit the throttle for max usable power without blowing the tires off....launching like that with a bit of wheel spin he was pulling like high 1.9x 60's on street tires.
Old Apr 28, 2010 | 03:50 PM
Riptide's Avatar
Riptide
That's the thing. The only difference between the two in how I drove was TC. Leastways as far as I can remember. Shifted the same both times or at least pretty closely. When I got the 13.9 with the 2.0 60', had I left TC turned on, I bet it would've made an improvement and a significant one. That said, I did have a 3-4 shift in the picture after I got the 4.10 gearing which might account for a tenth of the difference.
Given these results that's why I asked the question about why people seem to not want to use this. It appears to help not hinder. IME anyway.
Old Apr 30, 2010 | 02:56 PM
Mishri's Avatar
Mishri
Mish-ogynist
hard to tell anything from those 2 times because of the difference in mods. only good way is to leave it on for a run and then turn it off for the next. I think I had left T/C on once and i had the same ET w/o it.
mrtrodonet
Sep 19, 2020 03:12 PM
UrS4
Oct 3, 2015 06:23 AM
breaking
Oct 2, 2015 01:27 PM
ChampInSD
Oct 2, 2015 04:55 AM
guitarman376
Sep 30, 2015 05:54 PM
