The Racers Bench Is the track just too much for you? Want to know what will beat what? Talk about it here!!
Critique my launch!
Old Jul 11, 2013 | 06:51 PM
moosestang's Avatar
moosestang
Default Critique my launch!
I'm really just looking for advice on what I can do to improve traction before i go back to the track. This is with frpp K springs, stock front struts, kyb gas-adjust rear shocks. 295/45/17 MT drag radials at 25psi. I let the clutch out a little to fast, but this was not a high rpm launch. I know drag radials need to be heated for best traction, but for the street I'd like to get the best traction possible. I have my pinion angle at 1.5 degrees negative, so I'm going to try shortening the upper control arm. I do realize this isn't the best type of road for traction. Are the stiffer shocks going to hurt traction? Yes I hit the rev limiter and my hand was quicker than my foot on the 1-2 shift.
Old Jul 11, 2013 | 07:03 PM
dared3vil0's Avatar
dared3vil0
The launch looked good, but man... Those shifts are sloooow.
Old Jul 12, 2013 | 03:12 AM
moosestang's Avatar
moosestang
I know and it's killing my ET. I thought it just felt like I was shifting in slow motion, but in reality, I am.
Old Jul 12, 2013 | 06:51 PM
UPRSharad's Avatar
UPRSharad
Former Sponsor
swaybar eliminator?
Old Jul 13, 2013 | 07:16 PM
moosestang's Avatar
moosestang
Originally Posted by UPRSharad
swaybar eliminator?
Are you talking about removing the front sway bar? I have both sway bars on the car.
Old Jul 13, 2013 | 07:44 PM
VistaBlueFrank68's Avatar
VistaBlueFrank68
Do you have the LCB's on? I believe you're always recommending them.
What Short Throw Shifter are you running? With one or two bottom brackets?
The deletes? that's the one that bolt the rear axil in ridged place, no side to side flex. You'll need to undo one side for the road and it will still suck.
I saw the shop I go to build a 9inch rear with those options on a S/C 2010 and it was a straight shot only car. I'm going to experiment with the Swarr-Bar, added to my LCB's with Eirbach springs struts, sway's and all adjustable BMR UPC/LCA/Pan.
Do you have a straight Shaft? if so get the steel braided clutch-line, not sure if your year is hydraulic or not but it does for the clutch what steel does for the brakes.
Question:
Have you put-in a 5 pnt harness? My shop wants to - Seats-out, rip-out the carpet and weld a plate and bolt to the center floor. That's about $500/1000 at $100 per hr. It's a Corbeau set-up and their site u-tube vid shows a drill hole to the leading edge bar on the seat frame to attach the bolt. I have and plan to use the stock seats and that means stock seat frames. I will check the O.E.M. frame and if it's wide enough, I'll drill it myself. Will do the passenger side first, incase I screw it up .Name:  5PntSeatsCorbeau_zpse805b002.jpg
Old Jul 13, 2013 | 07:58 PM
VistaBlueFrank68
Go PRO Hero3 attach it to your rear with a coat hanger and some duct tape.
I'll try it as-soon-as I get back, I believe that would be very interesting - seeing what all the parts are doing in seclusion, now revealed. Go PRO - White/Silver/Black, Silver can operate via remote and the Black will Wifi the picture to your phone.
Mine is roll-bar mounted to the gray harness bar. It will see out the window and record the shifts being made or botched
Old Jul 13, 2013 | 08:19 PM
moosestang's Avatar
moosestang
Question:
I have the CHE lca relocation brackets, along with sphon adj lca's and che adjust upper control arm. I've removed the front sway bar before, not at the track, but just to see if it improved weight transfer and it definitely does on my car, atleast it did before I changed my rear shocks. I have the original hurst short throw shifter and it works fine, I'm just not ripping it hard enough. Straight shaft? I have a 1 piece drive shaft.
Racers bench? really? I wasn't racing anyone.
Old Jul 15, 2013 | 07:34 PM
UPRSharad's Avatar
UPRSharad
Former Sponsor
Yep. That helps with drag launches. I was just brainstorming for ya.
Old Jul 17, 2013 | 02:03 PM
Stkjock's Avatar
Stkjock
Retired Mod
less pressure in the tires
remove the front sway will help with weight transfer as well
