Diablo Predator question?
Hi All
Just purchased a Diablo Predator for my 05 GT but when plugged in I can't get any display to come on at all, I then noticed its for a 2007 Mustang, should it light up at all being plugged into my 05 even if it doesn't work or is it likely to be bad?
Model number is : U7145
Hope someone can advise
Thanks
Stu
Thanks
Stu
Thanks Mike
At this point I am just trying to gauge if it works at all, shouldn't it light up being plugged into an 05 or will it work as expected! Just need to figure it out as I bought it used with a Supercharger and nothing I bought arrived as I expected.
Thanks
Stuart
Thanks
Stuart
Hi Mike
Thanks for the help , it says on the back PC7145 I belive as the label is worn, I finally got it working this morning after I took it apart and reseated the power cable so thats good news.
I plugged it in and it said my car was not in there database and it gave me a code to supply but I take it this still won't work with my 05?
Thank you again
Stuart
Thank you again
Stuart
Hi Mike
Says U7145
Then the Cal ID: FBHR2G4
As I can't fully test this on my 05 is there anyway to see if its locked on another car or if its good to use?
Thanks again
Stu
Says U7145
Thanks again
Stu
