Tuner Central Have a question about which hand tuner is best for your Mustang? Talk about it here!
PC7140 issues
Old Sep 10, 2012 | 05:36 PM
nc_lx5.0's Avatar
nc_lx5.0
Default Diablo PC7140 issues
Ok, I have a 06 GT w/5spd. Installed the ProCharger Stage 2 kit. I did have the BBK 62 mm TB on it and figured that was the reason for the car not running with diablo tune. I installed the Bama tune that has the bbk tb tune on it and the car the car would run.
Today I took the bbk tb off and installed the factory tb, returned the car back to stock tune. After this I installed the diablo tune for the stage 2 kit. Once the install was done I fired the car up. It ran about 3 mins and died. The message center said "check gas cap". The car will fire up but die immediately. I put the car back with bbk tb and Bama tune, car runs! My check engine light is on for the car running rich. I know why it's doing that cause of the larger injectors. Any ideas why the car won't run in stock form with the diablo tune??
Old Sep 11, 2012 | 12:04 PM
Mike@DiabloSport's Avatar
Mike@DiabloSport
Premium Sponsor
Can't say I have ever heard of such an issue, were there any trouble codes with the ProChrager tune?
FWIW, thats not a 'diablo' tune, its a tune developed by ProCharger that happens to be in a Diablo tool
Thanks
Old Sep 11, 2012 | 12:24 PM
nc_lx5.0's Avatar
nc_lx5.0
No trouble codes at all. Just when the car cuts off....message center says "check gas cap". Tried it several times even leaving battery unhooked for an hour. Still no go with procharger tune. Its weird that the car will run on the bama tune(set up on the 93 octane race tune) with the procharger.
So, since it's a procharger tune I should contact procharger?
Old Sep 11, 2012 | 01:00 PM
AMWill's Avatar
AMWill
Former Sponsor
nc_lx5.0,
I would take your Mustang to a reputable local Speed shop and get your Mustang dyno tuned. Each car has their own characteristics and there's probably some drive-ability tables that can be played with, easily. If you need help finding a quality Speed shop, give our Bama team a call @ 888.226.9764 and they'll be able to help you out.
Let me know how you make out with this or if you have any other questions!
Shane
I
Old Sep 11, 2012 | 01:06 PM
nc_lx5.0's Avatar
nc_lx5.0
Thanks Shane,
I was trying to get the car to run on the procharger tune since it would be setup for the larger injectors and wouldn't have to worry bout the MIL coming on. The Bama tunes runs the car but the MIL light comes on because of the injectors are larger than stock. My car is due for NC inspection and I was tryin to get it inspected by the 15th of this month.
I do plan on taking it to Pro Dyno in SC next month.
Old Sep 11, 2012 | 01:14 PM
Mike@DiabloSport
Premium Sponsor
Thanks Shane,
When you get a chance, load the ProCharger tune to the car, then connect to a PC and export the backup and last tune written files and send them to me at support @ diablosport.com please.
Thanks
Old Sep 11, 2012 | 01:21 PM
nc_lx5.0's Avatar
nc_lx5.0
Ok. After talking to procharger and Bama im stuck! Procharger won't support me since I'm the second owner and Bama won't send me just a injector tune because I installed the procharger so my tunes for life is void now!!! Great!!! Should've listened to Pro Dyno to begin with!!
Old Sep 11, 2012 | 01:31 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Did you not read MikeDiablo's last post before you posted???
Old Sep 11, 2012 | 01:37 PM
nc_lx5.0's Avatar
nc_lx5.0
Nope!!! If I did I wouldn't have posted my last post.
Thanks Mike...I will try to get that to you within the next few days.
Old Sep 11, 2012 | 02:33 PM
Mike@DiabloSport
Premium Sponsor
No problem, let me know and we'll check it out.
