Buzzing Stereo?
Old Mar 16, 2006 | 06:15 PM
HRnB's Avatar
HRnB
Administrator
Default Buzzing Stereo?
I have the factory mach system in my 03. Lately it will just start buzzing through the speakers and the sound rises and falls with acceleration and deceleration. Sounds like a short, but could be a low battery. Does anyone else have this problem?
Old Mar 16, 2006 | 07:24 PM
03YellowPony's Avatar
03YellowPony
Default RE: Buzzing Stereo?
ORIGINAL: HotRods_n_Booze
Booze...This is strange saying this to you..but you should post this in the Audio section...
Old Mar 16, 2006 | 07:40 PM
mustangman02232's Avatar
mustangman02232
could be the fuel pump, the sound rises and falls? do you have the volume control on where the faster you go the radio gets louder?
Old Mar 16, 2006 | 08:04 PM
03YellowPony
Sounds more like electrical interference..RF..On older models, I'd suspect the condensor on the alternator..but I don't think newer models have them anymore.
Old Mar 16, 2006 | 08:12 PM
p0rsche23's Avatar
p0rsche23
im gonna guess electrical,maybe a short or something behidn the radio,no clue tho,its not gonna be the fuel pump tho,low battery i dont think will have that effect on it...i think someone posted something about engine noise through their speakers a while back in the audio section...
Old Mar 16, 2006 | 08:58 PM
lilnicky068's Avatar
lilnicky068
your picking up engine noise. go buy a ground loop isolater and hook that up. might be kinda tricky with the mach system though
Old Mar 16, 2006 | 09:50 PM
gt96stang's Avatar
gt96stang
Sounds like it could be grounding somewhere... I know I had this problem when I installed my headunit and they had to completey rewire the car.. This usually doesn't happen with the stock systems though.
Old Mar 16, 2006 | 10:20 PM
HamMach1's Avatar
HamMach1
If the sound is increasing and decreasing then you probably have that thing on where when you go faster the volume rises and when you slow down the volume drops. Just hold your power button that turns on the radio...but im sure you already know that -_-
Old Mar 16, 2006 | 10:22 PM
03YellowPony
ORIGINAL: Slicktastyk Matt
It's a buzzing noise..not a volumn problem
Old Mar 16, 2006 | 11:06 PM
HRnB's Avatar
HRnB
Administrator
It's all factory and I've never altered the system. I figured I'd ask here first in case it's an inherent 03 V6 vert problem.
The problem just started and the buzzing is the same no matter where the volume is.
By the way Slicktastyk Matt, that volume up and down with your speed is annoying and I haven't figured out how to turn it off. So I hold the volume ****, then what?
