flowmasters
Old Mar 17, 2006 | 02:42 AM
strike1980's Avatar
strike1980
Default flowmasters
i just got my true dual flowmasters on but now my car feels like it shakes a little went im slowing down and when i put the car in park
is this normal? and i just have to get used to it or the muffler shop did something wrong?
thank you
Old Mar 17, 2006 | 03:10 AM
03YellowPony's Avatar
03YellowPony
Default RE: flowmasters
ORIGINAL: strike1980
thank you
Shakes?? Might be the rumble..take it back and have them check it out just in case
Old Mar 17, 2006 | 04:10 AM
strike1980's Avatar
strike1980
did you car rumbles a lot when you are stopping?
Old Mar 17, 2006 | 10:29 AM
Mr. Merk's Avatar
Mr. Merk
is it dumped under the car? also it could be vibrating on the body or tranny or crossmember
Old Mar 17, 2006 | 02:22 PM
HRnB's Avatar
HRnB
Administrator
Make sure they didn't alter your cats or sensors. Even a burned sensor wire can make your car run like crap.
Old Mar 17, 2006 | 02:27 PM
03YellowPony
ORIGINAL: HotRods_n_Booze
True, but that would throw a code and cause the CEL to light up
Old Mar 17, 2006 | 02:34 PM
HRnB's Avatar
HRnB
Administrator
Not always. I had a damaged sensor wire and it didn't throw a code. But after Ford replace it, it got rid of my rough idle.
Old Mar 17, 2006 | 03:22 PM
strike1980's Avatar
strike1980
the car runs really good its just the vibrations behime my seat that ones that i think are kind of stronge specially if im using the A/C or heater.
Old Mar 17, 2006 | 03:41 PM
J8851's Avatar
J8851
Behind your seat if your using heat or A/C.... Thats puzzleing
I know i have to replace my alternator very quickly because its on its last leg, its causing an annoying noise as well you can hear how hurt it is when you turn anything on in the car.
Old Mar 17, 2006 | 04:15 PM
2004YellowStang's Avatar
2004YellowStang
Could it just be the exhaust resonating?
