Ticking in the engine
Old Mar 18, 2006 | 09:07 PM
blkmustang629's Avatar
blkmustang629
Default Ticking in the engine
Every time i start my engine it makes a ticking noise under the hood on the passenger side, i had the car in a shop for a few days and the mechcanic said my exhaust maniflod may be lose...you think he's right?
Old Mar 18, 2006 | 09:16 PM
mustangman02232's Avatar
mustangman02232
Default RE: Ticking in the engine
most likely, either that or its a lifter
Old Mar 18, 2006 | 11:03 PM
Jugador's Avatar
Jugador
if his mechanic couldn't figure out the difference in an exhaust leak and a lifter ticking, he shouldn't be a mechanic. it should be easy to tell if the manifold is loose.
Old Mar 18, 2006 | 11:07 PM
03YellowPony's Avatar
03YellowPony
With the engine COLD, start it up and run your hand over the manifold WITHOUT TOUCHING IT!! See if you feel any puffs of air. If there are, you have a leak. If not, drain your oil filter, and then add a quart of tranny fluid to the oil. Run it a week then change the oil. The tranny fluid is a high detergent oil and if you have a sticky lifter, it can get rid of the crud makin it stick.
Old Mar 18, 2006 | 11:41 PM
ddeaton66's Avatar
ddeaton66
If it stops soon after (5min or less) prolly a lifter
Old Mar 18, 2006 | 11:45 PM
Clif Brohn's Avatar
Clif Brohn
Its a bomb, no doubt about it. If it isn't a filter problem, check oil levels and run a diagnostics check.
Old Mar 19, 2006 | 12:06 AM
99Stang_V6's Avatar
99Stang_V6
i have the same problem but with my driver side....i got a tune up like a week ago and they checked it out....it prolly is an exhaust leak...just like mine....i just wanna kno how much its gonna cost...im gonna fix the leak first b4 my o2 sensor...since that messed up due to the leak...
Old Mar 19, 2006 | 04:00 AM
lilnicky068's Avatar
lilnicky068
im having a similar problem... it sounds dead up like an exhaust leak when i first turn on the car... but after about 5 minutes of driving... it goes away. u guys say its a lifter problem???
Old Mar 19, 2006 | 04:03 AM
03YellowPony
ORIGINAL: lilnicky068
Could be either one. Metal expands when it gets hot. So could be a small exhaust leak or a sticky lifter.
Old Mar 20, 2006 | 02:21 PM
lilnicky068
true true. yellowpony... your a genious. i have come to learn that since ive been on the forums. im takin it to the shop this weekend and have them check for exhaust leaks
Nick Oliver
Oct 17, 2018 04:22 AM
SteelerNation82
Sep 16, 2015 07:11 AM
rksnow1
Sep 14, 2015 08:46 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
Emblazoned
Sep 3, 2015 10:45 PM
