need massive help
Old Apr 3, 2006 | 12:07 AM
carcrazy's Avatar
carcrazy
Default need massive help
91 ford ranger 2.3 L
Some of you might remeber that i had to take my whole intake system off to clean out oil after i bought the truck. I cleaned it all out and i finally got the time today to put it all back together, but of course theres a problem.
just above the oil filter ( and under the intake maifold ) there is an oval shaped object connected to the block with a black hose coming out of it. When i took the intake off i diddent even see that slide off, or see it at all for that matter! I noticed it when i was putting everything back together. I looked all around and i couldent find where this black hose went..so...i just left it thinking maybe it just hangs there...Big mistake....I started the truck and it went to 3000 rpm right away, check engine light came on, and this hose sprayed oil F***ing everywhere.....So what is this thing?! and where does it go?!?!?
Old Apr 3, 2006 | 12:14 AM
Dan9687's Avatar
Dan9687
Default RE: need massive help
Hmm...I was thinking maybe a sensor but that wouldnt cause ur oil to fly everywhere.....it probably has to do something with oil pressure or somethin because it made your oil spit out and your RPM's jumped up.....but this is my opinion.
Old Apr 3, 2006 | 12:20 AM
carcrazy's Avatar
carcrazy
its a 1 inch diameter hose ( same as like vac hose but 1 inch ) about 6-8 inches in lenght
Old Apr 3, 2006 | 02:11 AM
86_SVO_Tim's Avatar
86_SVO_Tim
Don't feel bad, i parked my 86 2.3 SVO for the winter and when i got it out a few days ago mine is idling about 2500rpm's and sprays oil from an unknown place when the motor is under a load. If i figure it out soon i will share the info.
Old Apr 3, 2006 | 02:33 PM
carcrazy's Avatar
carcrazy
ORIGINAL: 86_SVO_Tim
Is it on the driver side? Near the oil filter?
Anyone else with info?!
Old Apr 3, 2006 | 02:45 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Probably part of your PCV system. That hose probably attaches to your Valve cover and is attached to the PCV valve stuck in the cover. If it's spraying oil, the oil deflector (baffle) in the valve cover is probably missing or damaged.
Old Apr 3, 2006 | 03:06 PM
carcrazy's Avatar
carcrazy
ORIGINAL: Derf00
there is no pcv valve in the valve cover and the hose is about 15 inches to short to get to the valve cover...
Old Apr 3, 2006 | 03:16 PM
alexr's Avatar
alexr
if you have a turbo, could it be your return line from the turbo?
Old Apr 4, 2006 | 04:20 AM
carcrazy's Avatar
carcrazy
its a non turbo 2.3 L
I really really dont want to take the intake off again and have to go through that whole hassel again =-[
Old Apr 4, 2006 | 04:38 PM
carcrazy's Avatar
carcrazy
anyone with an idea?
