Could I hit 14's?
Old Apr 10, 2006 | 11:56 AM
Dan9687's Avatar
Dan9687
Default Could I hit 14's?
Is it at all possible to hit 14's with the following mods:
- 65mm throttle body (with ported intake to match)
- True duals with flowmaster 40's
- u/d pulleys
- MAC CAI
- 3.73 gears and T-lok
- Cobra rims with performance tires
These mods would be on a 99' V6 stang 5spd.
Also.....does anyone have a rough guess of what hp/tq I'd be pushing with these mods?
Old Apr 10, 2006 | 12:55 PM
04_Sixer's Avatar
04_Sixer
Default RE: Could I hit 14's?
I've heard the T/B is a worthless mod on a mostly stock car. I think you'll be looking at consistent mid-low 15s.
Old Apr 10, 2006 | 01:56 PM
mustangman02232's Avatar
mustangman02232
the TB will do a little,
would be as in they are not done yet? are you staying N/A, forget the 3.73s and go 4.10s
edit: BTW, if you dont have an MAC CAI you can PM me cause i got one that dont fit
Old Apr 10, 2006 | 03:35 PM
zarins04stang's Avatar
zarins04stang
YOU CAN DO IT!!!!!
Old Apr 10, 2006 | 04:19 PM
tightdogal's Avatar
tightdogal
lets see...
flow 40's, CAI, and UD Pulleys~maybe 15 RWHP max
TB: meh
3.73 gears: that should be great with the accleration, just curious, why didnt u go with the 4.10's?
in any case, a stock manual v6 is capable of mid 15's, so you should be at low-mid 15s now. i think if u had the 4.10's, ud be there at 14.9 with that manual tranny
Old Apr 10, 2006 | 05:45 PM
TorchV6's Avatar
TorchV6
I would not go 4:10s if I had the money to go with gears either. I would go 3:73s for sure just because i wouldnt want it to hurt my top end and I also wouldnt want it to kill my gas mileage. O and dont forget about the annying whine of the 4:10s
Old Apr 10, 2006 | 06:24 PM
blkmustang629's Avatar
blkmustang629
Yeah you can hit 14s with those upgrades, but you would have to have that all tuned. With a manual tranny you can maybe even run mid 14s if your a bad *** driver
Old Apr 10, 2006 | 06:26 PM
nanaki's Avatar
nanaki
Retired MF Moderator
ORIGINAL: TorchV6
hmmm.. how often do you plan on going 160mph+? gas mileage? going from 23mpg to 22mpg hurts you? stop being a jew!
blkmustang629
with all those mods your running around 175rwhp to 180rwhp...but if you get it tuned, then maybe around mid to high 180rwhp...thats around 220 to 230 hp at the crank
ORIGINAL: Dan9687
- u/d pulleys
- MAC CAI
Old Apr 10, 2006 | 06:41 PM
mustangman02232
ORIGINAL: TorchV6
[sm=chairshot.gif]
1.) if installed correctly gears dont whine
2.) 03yellowpony gets better mpg then me with 4.10s then stock 3.27s
3.) they lower your top end, so you raise your top speed alot of people use these terms interchangably, you will have a higher top speed with 4.10s then stock
