Last edit by: IB Advertising
Browse all: Engine and Powertrain
- Ford Mustang V6 1994-2004: How to Adjust Throttle Cable
Step by step instructions for do-it-yourself repairs.
Full Throttle - 99-04 throttle cable adjustment/fix
ORIGINAL: redass02gt
didja ever find out the inner dia. of that tubing?
Im making a note of it and Ill post tonight when I get home. The tubing I had was actually a bit bit so I cut a small section as opposed to making a slice. If you look in the picture you can see that the tubing overlaps a bit. But like I said I will find out the proper inner diameter for you tonight.
no worries, do you have an estimate or a range? I think i'll stop by the hardware store on the way home and pickup stuff to do that. I'd rather buy 3-4 sizes than have to go back again.
btw, your writeup is 8 billion times easier to read and understand than any of the other write ups for this mod. good pics too.
Um, I would say that you would be very safe with an inner diameter of 1/4", I think 1/2 inch inner is too big, so somewhere in between. The smaller the inner diameter the better, all it has to be able to fit is a thin cable. If you just crawl down there and look it will give you a very good idea of what you need.
yea i love this mod. i did it a while ago and the few people who have driven my car sinse then always freak me out because the car jerks forward real bad when they hit it and dont mean to give it that much gas. most of them are in awe after that.
I did this mod to my car. I dunno if the gas pedal height is the same, so the spacer lenght might vary. I got a nylon spacer, about 3/4 of an inch long, from the elctronics parts store (they are usaed for mounting circuit boards). It's about 1/4" outer diameter, 1/8" hole. I took one end of the spacer and bored out the middle with an xacto knife until it would fit over the **** on the end of the gas pedal so the spacer would be flush against the flat stop on the end. I took one side, and cut out the slit with a razor (you can use a bike brake cable to make sure your slit is wide enouhg to fit over the cable without having to get into the car to check). I used one of these (1/4" i.d.) and nut/bolt/lock washer combo to secure it: http://www.picocanada.com/catalogue/7314-7329.asp
or
http://www.wmbs.hdweb.com/item.html?itemid=421573148
the one I used if jt&t products (jttproducts.com) part # 4464F, but I couldn't find the link anywhere for it.
10-32 x 1/2" nut/bolt combo was perfect for me.
or
