When to Use Overdrive button :)
Old May 3, 2006 | 10:45 PM
Lancerzor's Avatar
Lancerzor
Default When to Use Overdrive button :)
Okay on a 94 V6 when should i Use the O/D Button, i just realized mine worked. Like at what speeds and how long of a drive?
Old May 3, 2006 | 10:49 PM
ts91stang's Avatar
ts91stang
Default RE: When to Use Overdrive button :)
when on the highway/interstate, when youll be going at the same speed for a long time
Old May 3, 2006 | 10:53 PM
Lancerzor's Avatar
Lancerzor
ORIGINAL: ts91stang
k i knew that much hehe but okay well here is my real question I drive about 8 or 9 miles on the interest to school/work so during that time if there is no traffic and i go a constant 60 or 70 should I turn my overdrive on for that?
Old May 3, 2006 | 10:59 PM
ts91stang's Avatar
ts91stang
it wouldnt think it could hurt to use it i just leave mine in overdrive all the time and havent had any problems, the overdrive went out once but that was also at 220K mi.
Old May 3, 2006 | 11:02 PM
ByPopularDemand's Avatar
ByPopularDemand
Whenever you start the car the overdrive is on, its also called fourth gear
Old May 3, 2006 | 11:03 PM
Lancerzor's Avatar
Lancerzor
ORIGINAL: ts91stang
all time time even on regular streets??? and does the O/D take away HP or anything else?
Old May 3, 2006 | 11:05 PM
ByPopularDemand
O/D and power questions tend to lead to pointless debates in this forum. I suggest punching it with the o/d on then again with the o/d off and seeing what you feel
Old May 3, 2006 | 11:16 PM
Lancerzor's Avatar
Lancerzor
ORIGINAL: ByPopularDemand
Good Idea I'll try it tomorrow
Old May 4, 2006 | 12:07 AM
laserred38's Avatar
laserred38
THANK YOU....jeez....when you press the button do you see the little green light comes on saying O/D OFF...and you feel a downshift??....actually since my car was a handmedown from mom (she didnt know how to drive stick) i DESPERATELY want to convert it to a T5....but until then i make do by going from one....to two....to D with o/d off......to D with o/d on....SAD is it not????
Old May 4, 2006 | 01:07 PM
LIstang95's Avatar
LIstang95
Ok..very simply....when you are driving on local streets O/D off. When you are on the highway or press the O/D buthttps://mustangforums.com/post.asp?do=reply&messageID=1334230&toStyle=tm#
Click here to upload!ton so you can get fourth gear.
