4cyl conversion.. ?
Old May 8, 2006 | 07:31 PM
Stangsational's Avatar
Stangsational
Default 4cyl conversion.. ?
Hey guys, just out of curiosity what would it take to create a monster?
Im considering purchasing a 4cyl notch w/ t5 and swapping for a 2v 4.6/t45 (im on a budget cant afford a 4v 4.6 nor a t56). Im curious what other components need to be swapped for the benefit of performance, Im concerned about breaks, rear end, etc.
Experties is needed, thanks
Old May 8, 2006 | 10:59 PM
Jugador's Avatar
Jugador
Default RE: 4cyl conversion.. ?
for some reason even a 2v 4.6 doesn't exactly scream "budget" to me. why not just go 5.0 if you're not working with a ton of dough?
Old May 9, 2006 | 01:56 AM
Stangsational
From what i research I had better luck finding a 99+ 4.6 2v with low milage for a the same price I can get a 5.0 in worse shape. Plus performance plays a factor.
Old May 9, 2006 | 02:53 AM
Jugador's Avatar
Jugador
if performance plays a factor then why go with the one that you have to get a bunch of random expensive parts to complete the swap and a lot of wiring headache instead of using the amount you save to mod the 5.0 which is a lot easier to switch in?
Old May 9, 2006 | 03:02 AM
Stangsational
I guess, but in any case even if i got with a carbed 5 are the chassis components the same as a gt. Such as the rear end, breaks, etc.?
KILLER408
North East
Aug 2, 2005 10:44 AM
73Cleveland
Jun 17, 2005 12:36 AM
acousticrawk
May 6, 2005 12:11 AM
Sweeper
Apr 29, 2005 01:40 AM
Skitter
Apr 4, 2005 03:18 AM
