Yes your comp does throw a code for engine misfire, ive had tonz of experience with this issue lately... half of my cylinders have now misfired =\ the light will keep blinking until the engine is shut off or stops misfiring. There are a lot reasons for misfire too; coil pack, spark plugs, spark plug wires, water in cylinder(headgaskek blown), oil dripping on spark plug (valve not sealing), not enough fuel, not enough air, pistion ring broken, and so on.
If your motor shakes abnormally then its misfiring, if you want i can take a vid of mine shaking so you can compare yours, my fifth cylinder is still misfiring atm. So im going to just get a new motor, i cant firgure it out, its not any of the igntion stuff its not a head gasket, its not the valve train, i really dont know what it is =( so im going to get a new motor!!
It shakes at idle and it sounds COMPLETELY jacked up when i rev it, You know how our sixers have an even exhaust pattern with straight pipes? well i have straight pipes and its way off now. Ill take a vid and show you
