smoke?
Old May 14, 2006 | 11:42 AM
amrcnidyot's Avatar
amrcnidyot
Default smoke?
the other day i was passing someone and as i looked back, it looked like a big puff of smoke had come out of the tail pipe right as i hit wot. on of my friends told me he saw this happen a long time ago on my car. i didnt see it so i didnt know what he was talkin about and didnt care. anyone know why every once in a whie it does this?
Old May 14, 2006 | 11:52 AM
product1620's Avatar
product1620
Default RE: smoke?
Because you have pieces of chrome on your fenders, take them off and it will stop. J/K
What color is the smoke? Does it only happen under acceleration?
Old May 14, 2006 | 12:22 PM
blkmustang629's Avatar
blkmustang629
Default RE: smoke?
I work on disel trucks and when theres black smoke coming out the exhuast its usually a miss firing piston or a dead one...in your case, im not too sure, but maybe your losing a piston at certain times while accelerating...if you can, try to get a program tuner pluged into your car, you might get some trouble codes back that show you what the problem is for sure...you dont need an aftermarket tuner...all good shops should have some kind of programer that checks for codes, should cost less than 100.
Old May 14, 2006 | 03:09 PM
amrcnidyot's Avatar
amrcnidyot
Default RE: smoke?
yea it happens very rarely when i accelerate hard. its dark grey almost black smoke. and it only happens once...just one shot of smoke. and it seems to still have plenty of power. and ill see if i can check the computer to see if i get anything.
ps. i took off the chrome the other day to wash, clay, glaze, and wax it and i actually want to keep it on. ive had many doubts about it before. if i ever did anything else to the exterior i would probably want to take it off because it would be just too much.
Old May 14, 2006 | 07:10 PM
product1620
Default RE: smoke?
Black smoke means that your running rich; check your engine oil for fuel contamination (take your dip stick out examine and smell for gasoline) if the oil dosent have gas in it then I would guess a sensor or a leaky injector. Now if it is a dark grey or blueish color then you are burning oil but I doubt that would happen to a newer car like yours, so it probably is just running a little rich.
Old May 15, 2006 | 05:42 PM
amrcnidyot's Avatar
amrcnidyot
Default RE: smoke?
so i took my car to autozone to have a diagnostic done and there were no trouble codes. i told them about what happened and someone there said my pcv valve was probably sticking. i dont think he was right because i replaced that less than a year ago but i got a new one anyway..it was less than 2 bucks...now i get to wait and see if it ever happens again.
Jan 21, 2016 01:30 PM
RCS02v6
Sep 29, 2015 01:46 PM
MacSerio
Sep 27, 2015 01:05 PM
Ipaman
Sep 22, 2015 07:01 AM
fastbackford351
Sep 12, 2015 09:42 AM
