posi + gears = THE WIN!
Old May 23, 2006 | 01:56 PM
lilnicky068's Avatar
lilnicky068
Default posi + gears = THE WIN!
yo guys. purchasing option B from here http://rpmoutlet.com/newv6m.htm the posi-trac and i think im getting the 3.73 gears. im pretty vehicle-savvy so i feel comfortable installing it myself. anybody had any experience with this???
Old May 23, 2006 | 02:05 PM
mustangman02232's Avatar
mustangman02232
Default RE: posi + gears = THE WIN!
1.) do NOT install them yourself
2.) stop listening to people with no gear experience
Old May 23, 2006 | 02:50 PM
lilnicky068
why not?!?!?!
and im not LISTENING to anybody... i want 3.73s
Old May 23, 2006 | 03:13 PM
Crzybiker's Avatar
Crzybiker
You do not possess the skills, knowledge, or tools to properly install a differential and rear gears.
Old May 23, 2006 | 03:14 PM
HRnB's Avatar
HRnB
Administrator
Gears aren't hard to install, but installing and shimming them correctly is the key to a good install. You don't get a second chance, they will be damaged immediatly if they aren't installed correctly. I'm a good mechanic, but I had my friend that owns a tranny shop install mine. He's been doing it for about 25 years.
Note the yellow paint in the pics. This is done a half dozen times to test and adjust the tolerances. Then after the first test drive with a break in fluid, it's taken apart again and re-adjusted.
Here's my install: >> http://www.cardomain.com/ride/450179/5
Old May 23, 2006 | 03:23 PM
04Mach1DD's Avatar
04Mach1DD
ORIGINAL: mustangman02232
1. installing gears isnt hard AT ALL, just make sure you read up on how to correctly shim, and do a proper allignment.
2 yes he is right, do not listen to him, just dont go anything below that because its just a total waste. also remember to buy a name brand(royal purples great) to use in your rear end. and friction moddifier
Remeber to read up on it first because it can be hard if you dont, but will make a difference.
Old May 23, 2006 | 03:27 PM
HRnB's Avatar
HRnB
Administrator
Also, don't buy used gears off of ebay. Most of them are spanked and that's why they are selling them. Spend the 200 bux and get new Ford Gears, you won't be sorry.
Old May 23, 2006 | 03:41 PM
lilnicky068
ah geez. didnt know about all the alligning crap. know of any good articles that would explain how to do it??? maybe i would be better off paying 300 bucks for someone else to do it
Old May 23, 2006 | 03:43 PM
Crzybiker's Avatar
Crzybiker
You would be much better off letting someone else do it. It's great and all to read up and learn and try stuff on your own but be realistic about your own skill level. Trying you first gear swap on what I'm guessing is you daily driver is not a wise decision.
Old May 23, 2006 | 03:44 PM
lilnicky068
yea true. iiiiiii'm retarted. thanks crzybiker. by the way... what kind of bike you got?
