Which has better performance?
Old May 23, 2006 | 10:58 PM
Stang562's Avatar
Stang562
Default Which has better performance?
I was wondering which would get better performance
A 1995 mustang with a 99 v6 engine
or
A 1999 mustang v6
I was wondering this because of weight differences and transmissions.
Old May 23, 2006 | 11:04 PM
99BlackV6's Avatar
99BlackV6
Default RE: Which has better performance?
It's not worth it to put a 99 V6 in a 95. It will probably be a little faster but not much. They don't weigh all that much different.
Old May 23, 2006 | 11:36 PM
jthorn9's Avatar
jthorn9
The Godfather
Ummmmmmmm...................the 99 by like a mile. 95 V6 - 145 hp ->= 110-120 rwhp, depends on auto or manual tranny, 99 V6 - 190 hp ->= 150-160 rwhp, tranny type pending.
Old May 23, 2006 | 11:49 PM
Crzybiker's Avatar
Crzybiker
Reread his question.
The main difference between the two was sheetmetal, so I don't think there is going to be a noticable change in performance if using the same engine.
Old May 24, 2006 | 12:02 AM
jthorn9's Avatar
jthorn9
The Godfather
Actually, there would be a huge difference, "IF" he does just an intake swap, the entire engine isn't neccessary unless his old ones fried, but a 99-04 set up, or intake swap, alone, will net you another 40 rwhp, and providing you use the same cam, you would actually net 42-44 hp as our cam is actually slightly more aggressive than the 99-04 cam, do a cam swap along with this mod then you could net up to70 or so rwhp, although 55-60 is a little more reasonable, get those heads and intake polished with an inlarged throttle body, then 200 rwhp isn't out of the question.
Old May 24, 2006 | 09:40 AM
mustangman02232's Avatar
mustangman02232
ya thats work, if you were to have both stock with the same tranny, it would be close, 94-98s are lighter but they have 2.73 gears
Old May 24, 2006 | 07:44 PM
JT76's Avatar
JT76
94-98 V6 is a turd. the 99-04 V6 isnt all that bad. With a few mods they can be pretty quick. My buddy has an 03' V6 auto with my stock pipes and he took a few Camaro V6's which are supposedly faster
Old May 24, 2006 | 08:11 PM
ByPopularDemand's Avatar
ByPopularDemand
Camaro and stang(both 6ers) is a drivers race. and isnt it only the 96 cam which was a tad more agressive
Old May 24, 2006 | 09:56 PM
Clif Brohn's Avatar
Clif Brohn
ORIGINAL: jthorn9
So. 200rwhp W/ JUST, split port swap, larger throttle body and a head polish? I think not. The TB wouldn't do a dam thing without getting the intake ported to match the new diameter. Also, what cam are we talking aboot here? The SN95 3.8 cam? Or an aftermarket cam? If SN95 cam, not worth the trouble of swapping out cams for the 5-10 HP you'd get. Even then, I'm pretty sure BPD is right about the "slightly"(and I use this term with extreme prejudice, there isn't hardly any difference) more aggressive cam being used in the "96 3.8 only. I lurve ya Jthorn, but I gots to do it......[sm=bs.gif] [8D]
Old May 24, 2006 | 10:08 PM
mustangman02232
ORIGINAL: ByPopularDemand
a 3800 camaro should be a drivers race with an NPI GT
