hp?
Old May 24, 2006 | 03:20 PM
00mustang's Avatar
00mustang
Default hp?
if i got a 4.3 stroker kit and a stage 3 power pack from supersixmtosports.com and also got a procharger. how much HP do you think i would get?
Old May 24, 2006 | 03:26 PM
JoJo96Vert's Avatar
JoJo96Vert
Default RE: hp?
I'm not positive on numbers, but it would be a lot. My only question is, so you realize how much that is gonna cost? If you can afford it, you'll have a bad a$$ car, but its gonna cost a ton to do that.
Old May 24, 2006 | 03:29 PM
00mustang's Avatar
00mustang
Default RE: hp?
i have about 5,000 saved up and plan on doing it by the end of next summer...
Old May 24, 2006 | 06:27 PM
tims 88 4's Avatar
tims 88 4
Default RE: hp?
id say go for it man if you have enough money saved up let your imagination run wild but first start with the little things if you dont already have them just make sure you dont over spend and break the bank
Old May 24, 2006 | 08:10 PM
nanaki's Avatar
nanaki
Retired MF Moderator
Default RE: hp?
you're going to need quite a few other mods to get that power to the ground. start with the blower.
Old May 24, 2006 | 08:13 PM
ByPopularDemand's Avatar
ByPopularDemand
Default RE: hp?
Why not start with the heads&cam then suspension then build the motor then blower
Old May 24, 2006 | 09:09 PM
tightdogal's Avatar
tightdogal
Default RE: hp?
get good suspension as well. no use having all that power in the engine if you cant get it to the wheels.
