Manual Transmission
Old Apr 17, 2004 | 01:58 AM
Xatrius's Avatar
Xatrius
Default Manual Transmission
Ok, well I want to switch my Auto to Manual. Auto 2.3L are slow as heck......enough to drive a man crazy. And I am about to go to collage so I don't want to be spending a crap load just yet.
So what I would like to know is exactly what ALL parts I will be needing for this switch, to make it proper. Thank you to anyone willing to take the time to make that list for me. It is greatly appretiated.
Old Apr 17, 2004 | 03:24 PM
Ftr-Speedy's Avatar
Ftr-Speedy
Default RE: Manual Transmission
this was for a 1990 Le Baron
Junk yard:~$400
Transmission
Fly Wheel(if you’re lucky you can get the clutch assembly, for a core return, from the yard)
Shifter & Cables(assembly make sure you get the bushings and retainer clips for the shifter cables)
Brake/Clutch pedal with clutch cable(assembly make sure to get clutch cable retainer)
Dealer:~$80
Fly Wheel Bolts(8)
Pressure Plate Bolts(6)
Transmission Mounts(2)
Auto Zone(or preferred auto shop):~$150
Clutch Kit(clutch, pressure plate, bearing, alignment tool)
Brake cleaner(to clean pressure plate and fly wheel contact surfaces)
Thread Lock(Make sure them fly wheel bolts don’t come loose)
Old Apr 17, 2004 | 03:27 PM
Ftr-Speedy's Avatar
Ftr-Speedy
this was for a GTS i think
Transmission
flywheel
bell housing (on some years)
torque tube
rear cross member
brake pedal
shift lever and trim
You will need to add the following:
clutch kit
intermediate plate
short shaft
guide tube
pilot bearing
clutch arm
pivot bushing
clutch slave
clutch master
clutch lines
shift coupler
forward ball socket
shift rods
You will also need to modify your firewall to install the clutch master.
i mean take your pick for every car is different, wasn't able to find nething on a ford mustang tranny swap.
4cylinderplus2
Oct 9, 2020 07:45 PM
b8checker
Oct 8, 2015 12:55 PM
BeatnikFink
Oct 1, 2015 08:00 PM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
