Gear/posi programming?
Old Jun 4, 2006 | 03:03 AM
02MustangV6DD's Avatar
02MustangV6DD
Default Gear/posi programming?
i have been talking to alot of people this weekend about gears, they say i dont NEED to tune my car to do gears and it just effects the speedo. is this correct? because i have the gears sitting here but i cant put them in yet, 1 because no tuner, and 2 still awaiting bearing. so thanks
Old Jun 4, 2006 | 03:17 AM
03YellowPony's Avatar
03YellowPony
Default RE: Gear/posi programming?
ORIGINAL: 02MustangV6DD
You will either need a tuner, or a speedocal to reprogram the speedometer. When I had mine installed, I forgot to bring the tuner with me when I picked the car up. Now, the shop was aboot 25 miles away, and I had to drive it home and not know how fast I was going. I found out it was aboot 20-25 MPH off.
Old Jun 4, 2006 | 03:29 AM
02MustangV6DD
but is that all that it effects is the speedometer? because if it is im in luck. ford installed my roush speedometer and it said i was doing 50, and the electric thing i have said 70
Old Jun 4, 2006 | 03:34 AM
alexr's Avatar
alexr
if you dont have a tuner, just get one of these:
Old Jun 4, 2006 | 03:38 AM
03YellowPony
ORIGINAL: ARdoller
Won't work on 99+'s. 99+'s are electronically controlled.
03YellowPony
Yes, the speedometer is all the gears will effect.
Old Jun 4, 2006 | 11:33 AM
mustangman02232's Avatar
mustangman02232
ORIGINAL: 03YellowPony
well the odo too
Old Jun 4, 2006 | 11:41 AM
randy78045's Avatar
randy78045
Install the gears... tune later...
Old Jun 4, 2006 | 03:30 PM
02MustangV6DD
k, thanks. the dealer has to do that anyway sometime this month so ill just get them installed, and then take the car in
panic
Aug 28, 2015 02:37 AM
MusBBad95
Aug 17, 2015 09:39 PM
