Power Steering!!!!!
OK....I am installing a Procharger an i had to extend the power steering cooling lines in order to fit the intercooler (3 core) obviously the fluid came out no biggie well i installed the intercooler an topped off the fluid...i also bleed the line now it makes this horriable noise the pressure is fine no restrictions in movement but i have no idea what this noise is! any help!?!?!
Sounds like the P/S pump is ready to go. I have a 00 V6 myself and just over 100K on my car. Mine is starting to wail sometimes. I'm not familiar with the Procharger setups. Do they use one drive belt to run all the accesories and the charger itself? Extra drag caused by the charger is probably pushing your P/S bearings to the brink of death wth teh extra load.
(Did you have to remove the P/S pulley at all?)
ORIGINAL: 006Banger
Yes the procharger uses a one belt system but the blower is not on yet! so not the problem also my car only has 42000 miles! ok yellow i will try that i didn't do that when i bleed them not even sure if i bleed them right! what is the proper procedure when bleedin the system?
ORIGINAL: 006Banger
KingRando
Oct 2, 2015 08:06 AM
Sep 25, 2015 06:58 PM
