Where to buy???
Old Jun 18, 2006 | 12:04 PM
blackbetty00's Avatar
blackbetty00
Default Where to buy???
I want to buy 4.10 gears and t-lok differential. Where do i buy these? What do i need to make these work (installation kit, bearings, etc.)
Old Jun 18, 2006 | 01:02 PM
mustangman02232's Avatar
mustangman02232
Default RE: Where to buy???
PM autobadges.com, he can get you hooked up with them
Old Jun 18, 2006 | 01:57 PM
3.8blackout's Avatar
3.8blackout
As far as i know, you need the gears, t-lok, bearing kit, dif. fluid, and a tuner or speedocal (im guessing your a 2000 stang) to fix your speedometer. Another good place to check at would be RPMoutlet.
EDIT: as for the install, i think most people will recommend you take it to a shop and let them install it. It will probably cost around $250 but its well worth the hassle of installing it yourself and having an annoying whine or short lifespan.
Old Jun 19, 2006 | 12:20 AM
jthorn9's Avatar
jthorn9
The Godfather
I say check out http://www.mustangtuning.com/ for the gears, oil, tuner, and bearings, and http://www.v6mustangstuff.com/ for the T-lok and 23 tooth speedo gear (94-98).
Old Jun 19, 2006 | 01:01 AM
03YellowPony's Avatar
03YellowPony
ORIGINAL: jthorn9
Sorry...the FRPP gears are a little cheaper HERE , and they also offer the FRPP T-Lok, wheras mustang tunning doesn't. The FRPP T-Lok will be strong enough for most apps..up to 350 HP. AND, the FRPP gears are stronger than Motive. Even tho Motive makes them, they are made with stronger metals.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
winner99
Oct 1, 2015 10:52 AM
guitarman376
Sep 30, 2015 05:54 PM
mustangheaven
Sep 29, 2015 11:00 AM
Sep 25, 2015 06:30 PM
