Weight reduction
Old Jun 22, 2006 | 12:00 PM
Jefferson's Avatar
Jefferson
Moderator
Default Weight reduction
How much do the seats weigh in my 99, the driver seat is power.
Old Jun 22, 2006 | 01:50 PM
gdcpony's Avatar
gdcpony
Default RE: Weight reduction
I think I lost about 35 when I swapped mine for a standard seat.
Old Jun 22, 2006 | 01:52 PM
Jefferson's Avatar
Jefferson
Moderator
k, thanks.
Old Jun 22, 2006 | 01:54 PM
jthorn9's Avatar
jthorn9
The Godfather
Not too sure, but if I had to guess, I'd say around 60lbs or more.
Old Jun 22, 2006 | 02:48 PM
Rook6's Avatar
Rook6
Anyone know how much weight you lose with a rear seat delete?
Old Jun 22, 2006 | 04:45 PM
MACHJUAN's Avatar
MACHJUAN
about 50 for the rear
Old Jun 22, 2006 | 07:19 PM
gt96stang's Avatar
gt96stang
ORIGINAL: redv6pony
I highly doubt you lose 50 lbs from taking out the rear seat... I took mine out for a rear seat delete and can say that it does not weigh 50 lbs... I would personally say it would be the last thing that you would do if you had a car that goes to the strip a lot, or if you are like me, and nobody sits back there, then it's fine.
Old Jun 22, 2006 | 07:33 PM
P Zero's Avatar
P Zero
Some things you can remove to reduce weight, rubberized undercoating, the sound deadening stuff under the carpet (-/+ 30lbs.), get a fiberglass hood (20lbs?), get racing seats for the front up to 50lbs per seat, inner fenders, smog pump and air tubes, emissions stuff (if you can in your state), get an aluminum driveshaft, remove the spare and jack/tools, just my .02.
-P.
Old Jun 22, 2006 | 11:06 PM
Jimmz's Avatar
Jimmz
The have leather/suede cobra seats in the rear an id say they weigh about 20-25 lbs....
Old Jun 22, 2006 | 11:16 PM
ByPopularDemand's Avatar
ByPopularDemand
ORIGINAL: P Zero
-P.
Arent they all fiberglass
