clutch problems
Old Jun 26, 2006 | 11:56 PM
primuslesler's Avatar
primuslesler
Default clutch problems
okay today i was on a feeder street, seeing what my car has got. i.e. seeing how fast it can go. well i was shifting at about 5k rpms and when i went to put it in 4th gear i heard a little pop and then let off my clutch to keep going cept it didnt engage. the clutch pedal felt like it didnt go up as high as it usually does. so i turn onto a street to see whats wrong and i have to coast to a stop since pressing the gas wont make it move. well i stop it and i didnt smell the clutch burning so i turn the car on and try to drive it. it took alot of gas to make it move and then smoke started pouring out. the clutch was burning. so i turn it off real quick to try and save the clutch. have my friends dad drag it home and now its sitting there and i have no means of transportation. i havent been able to get under the car to see whats wrong yet because its night time. but does it sound like just the clutch cable came loose? because im screwed if its something else seeing as im broke.
Old Jun 27, 2006 | 12:24 AM
98ponycar's Avatar
98ponycar
Default RE: clutch problems
You only wish you could get that lucky. It's time to pull the transmission.
Old Jun 27, 2006 | 12:26 AM
primuslesler
so is the transmission fubar?
Old Jun 27, 2006 | 12:38 AM
98ponycar's Avatar
98ponycar
It has to come out. If the cable were broke, you would have no clutch at all, but instead, the clutch is actually disengaged, meaning that the input shaft isn't turning. Smoke came from the clutch. It's burned and needs to be replaced. The new clutch will come with a pilot bearing and throwout bearing. That will be all you need to fix the car.
Old Jun 27, 2006 | 03:33 AM
primuslesler
is there a possibility clutch got stuck halfway?
Old Jun 27, 2006 | 05:02 AM
andygap411's Avatar
andygap411
how would the clutch be toast?! he just needs to reconnectthe clutch cable to the thro out bearing... i was there when this happened my guess is the clutch is just glazed over.
Old Jun 27, 2006 | 02:09 PM
andygap411's Avatar
andygap411
back ttt
Old Jun 27, 2006 | 05:59 PM
primuslesler
ttt i need my car fixed
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
MasterLanMan
Sep 13, 2015 08:21 PM
Brandonfilipponi@yahoo.com
Sep 12, 2015 11:39 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
