What pipes to get?
Old Jun 27, 2006 | 05:29 PM
ilduce321's Avatar
ilduce321
Default What pipes to get?
Quick question or two, looking for suggestions and advice. I'm about to get dual exhaust put on my 2006 V6. I have Flowmaster American Thunder mufflers ready to go, I just don't know what route to go with the pipes. Should I go true duals, x-pipes, or h-pipes? Also, what, if anything, will this do for or against my mileage (I do a lot of highway driving)? Thanks
Old Jun 27, 2006 | 07:30 PM
ilduce321's Avatar
ilduce321
Default RE: What pipes to get?
So I don't sound like a complete idiot (although this will be hard), what I'm wondering is what's better and why: straight pipes, x-pipes, or h-pipes, and what effect will changing over to a dual exhaust have on my mileage?
Old Jun 27, 2006 | 09:56 PM
mustangman02232's Avatar
mustangman02232
x pipe, and get force flow mufflers from summit racing, same thing with a life time warrenty for $30
Old Jun 27, 2006 | 10:43 PM
98nymustang's Avatar
98nymustang
ORIGINAL: ilduce321
u can use those flows u have and get an x-pipe, better on the V6(not sure y, i was told but dont remember). Also. if u can, take off ur cats, if u have to have them to pass inspection, then get high-flow cats. Also new headders wouldnt hurt either, but the sound will differ with the setup.
Old Jun 27, 2006 | 11:23 PM
stangmpf's Avatar
stangmpf
True duals are the best as the least amount of bends are required, which means less restriction and better sound and power. always good.
in between a x and a h pipe is always a debate so i dont know.
dual exhaust will actually increase your mileage by a little but as the air flows freer and lowers the pressures on the hoses and the engine internals. also increases the car life that way
Old Jun 27, 2006 | 11:27 PM
mustangman02232
ORIGINAL: stangmpf
yes, but not enough back preasure will make you loose power
Old Jun 27, 2006 | 11:34 PM
03YellowPony's Avatar
03YellowPony
Here's a reality check. Unlike the V8's, the V6 doesn't NEED a crossover at all. The 3.8 is an even fireing engine, wheras the V8's are not. So back pressure is already equal. Now as far as sound goes, X-Pipe sounds better to me.
Old Jun 28, 2006 | 12:12 AM
gt96stang's Avatar
gt96stang
ORIGINAL: 03YellowPony
Finally....Someone that knows.. An h-pipe would be useless to you because the car is even fire.. So you can either go with true-duals, or get an x-pipe if you so choose... If a shop was doing it, I'm sure just going straight pipes would be cheaper.
Old Jul 5, 2006 | 09:46 PM
ilduce321's Avatar
ilduce321
Thanks everyone for your help, I really appreciate it. So, tell me if this is the gist of what's being said....
Straight pipes would be just fine and cheaper, otherwise go with x-pipes
Consider new headers
The Flowmasters should be sufficient
Like I said, thanks a lot. I'm still new to all this, I just want to make the best of my investment and my V6. I plan on having it for some time.
BW
Old Jul 5, 2006 | 10:22 PM
mustangman02232
headers will do nothing
