need advice
Old Jul 4, 2006 | 02:42 PM
tatstang's Avatar
tatstang
Default need advice
i have a 98 mustang V6 5 speed. i need some advice on how to get more hp and speed with a tight budget. i have already put new plugs, dual exhuast, and have a cold air intake. if anyone could help me i would greatly appreciate it. thanx
Old Jul 4, 2006 | 09:17 PM
98nymustang's Avatar
98nymustang
Default RE: need advice
ORIGINAL: tatstang
im goin to tell u what i was told and what everyone else is goin to tell u. gears, t-lock/detroit posi lock, aluminum drive shaft, suspension upgrades.. all of that will help u get that power to the ground. now for actual power the key is breathing, the engine has to breath properly. ok if u have to have cats, get high flow, or else u can take them off. get a high flow air filter for that cai. headers for the exhaust. if ur goin to stay n/a then get a new throttle body and throttle body spacer. get under drive pulleys, a set of 3 is good. get a short shifter and a short throw kit in ur clutch. then when ur ready for the bigger bucks, get forged internals, pistons, cams, crank, rockers, lifters, push rods, u can shave and bore. get a new fuel pump with bigger fuel injectors. u can get a stroker kit, 4.2 for n/a and 4.3 for forced induction. if u go F/I then an eaton supercharger is really good for this year(98), and u can go turbo as well, but many people have told me that a twin turbo setup is more efficent. if u go super keep the single port injectors, dont go split port, ull jus have to change back. u can also get weight reduction, take out useless sh*t like the back seat and things like ur ac compressor, if u dont use it or can live without it. im sure ive missed some things, but thats a pretty good list. and ull get alot of help from the people here. good luck and keep us posted, with pics if possible.
Old Jul 5, 2006 | 12:43 AM
jthorn9's Avatar
jthorn9
The Godfather
There are no cheap mods, remember, you've got to pay to play, but about the only cheap mod you have left is underdrive pulleys. Here's a few more mods for you, but they're far from cheap.
1.) Gears and a t-lok, we have more than enough gear threads to feed you more information than you could ever need.
2.) Handheld tuner
3.) Upper and lower intake port and polish, along with a head port match and polish, cam swap, injector upgrade, throttle body upgrade. Or you could do a split port swap intake swap to make your intake like a 99-04 and do all of those other things along with it.
Old Jul 5, 2006 | 12:44 AM
nanaki's Avatar
nanaki
Retired MF Moderator
or you can get a nitrous kit
Old Jul 5, 2006 | 12:46 AM
jthorn9's Avatar
jthorn9
The Godfather
Or that to, I'm just not too big on nitrous which is why I generally fail to reccomend it.
Old Jul 5, 2006 | 12:48 AM
nanaki's Avatar
nanaki
don't know why. it's just as safe as any other major power adder at a fraction of the cost. just like anything else, if you install it properly, you won't have any problems.
Old Jul 5, 2006 | 01:21 AM
pyromania's Avatar
pyromania
ORIGINAL: nanaki
until you run out. then you are slow again.
Old Jul 5, 2006 | 01:24 AM
03YellowPony's Avatar
03YellowPony
ORIGINAL: pyromania
ORIGINAL: nanaki
My real name is Matthockey32 and I lie through what's left of my teeth.
Old Jul 5, 2006 | 01:30 AM
alexr's Avatar
alexr
ORIGINAL: nanaki
i think adding nitrous is just begging you to go out and race and get a speeding ticket and/or get arrested.
you can say the same thing about a supercharger, but the fact that the supercharger is "always on" kinda dulls down the racing spark
i would think when people have nitrous, theyre driving around like "man i wanna race somebody so i can use my NOZZZZZZZZZZZZZZZ"
Old Jul 5, 2006 | 02:47 AM
561boii's Avatar
561boii
U/D pulleys, 4:10gears, t-lok and a tuner!
