CAI install.. help asap!
I'm in the middle of installing it, when I see the instructions are for 94-01, but the box and images show it to be for an 02. It's got the triangle filter or whatever... But it cant fit. where its supposed to go. Any help? do I have to install it from underneath my car?
its the mac for 99-04s from autobadges. the box it came in says 99-04, but the instructions say for 94-01. i have no idea if i have the right or wrong one... my car is an 02
ORIGINAL: mustangman02232
uh huh, PM autobadges.com hes on this site, a 94-01 will not work on a 02-04, in 02 they got the 3 extra HP and 5 ft.lbs of torque and moved the TB
i got the same cai from him and i was able to install, althought i wasnt able to fit the shield that came with it...it fits you just need to fiddle with it, i installed it all from above, except i put the filter in throught the bottom of the car... bottom line it should work.
This is the one I have, part 3620. I found a hole in the bottom to install like charcoal said. I just wanted to make sure I did infact have the right one.
Now whats easier, running the filter underneath then connecting it to the fender. Or... Installing the fender first, then the filter?
