Chirping?
Old Jul 11, 2006 | 12:06 AM
JoJo96Vert's Avatar
JoJo96Vert
Default Chirping?
For whatever reason there is a chirping noise coming from the front driver side of my car. I know that my alignment is slightly off and because of this my tire up there is pretty bald on the outside. Could this be causing the noise? I'm gettin new tires and an alignment later this week, so I'm hoping that takes care of it, but if not what else could it be?
Old Jul 11, 2006 | 01:01 AM
Allan_York's Avatar
Allan_York
Default RE: Chirping?
how did it get out of allignment?
Old Jul 11, 2006 | 01:07 AM
JoJo96Vert's Avatar
JoJo96Vert
Not really sure to be honest with you. I would assume it was from a pot hole or something, cuz I dont remember doin anything else that woulda caused it. Plus I do a lot of highway driving and the highways out here arent too great.
Old Jul 11, 2006 | 01:16 AM
03YellowPony's Avatar
03YellowPony
Could be a wheel bearing, or possibly a warped rotor/low pad.
Old Jul 11, 2006 | 01:17 AM
BeachStang04's Avatar
BeachStang04
are you sure its not the rear wheels when your shifting, i know i chirp everyonce in a while lol. Does it do it when you turn or during acceleration?!?!?!
Old Jul 11, 2006 | 01:48 AM
JoJo96Vert's Avatar
JoJo96Vert
ORIGINAL: BeachStang04
Its a continuous noise. And the only time that I usually chirp it is if I shift real high in the rpm range or if I break the rear end loose on a bumpy road. But anyway, the noise is continuous, and def comin from somewhere up front.
And Harv, if it is the brake pad, does it sound like that all the time or just while braking? Cuz thats something I was thinkin it might be, but I wasnt sure if it made the sound all the time.
Old Jul 11, 2006 | 01:51 AM
03YellowPony
ORIGINAL: JoJo96Vert
Sounds like a wheel bearing more than a brake pad...
Jack up that corner, and grab the wheel. Try to shake it. If it feels like it's loose, wheel bearing. Then spin it. If you hear the noise then, well...still could be a bearing, or the brake pad. Then take the wheel off and turn the steering wheel so you can see the pad. If it's really low, it could be the sensor scraping the rotor.
Old Jul 11, 2006 | 01:53 AM
JoJo96Vert's Avatar
JoJo96Vert
ORIGINAL: 03YellowPony
Alright, I'm gonna check it out on thurs when I'm off from work. If it is the bearing, how much would it cost to get it fixed, any rough guess?
Old Jul 11, 2006 | 02:51 AM
03YellowPony
Bearing will cost around 80-100 depending where you get it. Could be as low as $60. Install, I have no idea.
Old Jul 11, 2006 | 02:53 AM
jthorn9's Avatar
jthorn9
The Godfather
I highly doubt it's the breaks, most likely it's the wheel bearing.
