starting problems.
Old Jul 13, 2006 | 04:06 PM
lilozzy's Avatar
lilozzy
Default starting problems.
in the morning when i get up to go to work and when i get off of work i go to start my car and it doesnt fire right up. any ideas?
Old Jul 13, 2006 | 07:31 PM
nijoma's Avatar
nijoma
Default RE: starting problems.
throttle body control......common problem.....part is like $60.00...but ....
I would first try to clean it....you can remove it and clean it out
it is spring loaded and carbon builds up inside......get some brake cleaner and spray inside
mess a little with the spring pushing in and releasing.....if you have an air compressor use this also
This should take care of it
Old Jul 13, 2006 | 07:58 PM
65coupe88hatch's Avatar
65coupe88hatch
ORIGINAL: lilozzy
does it start then kinda try or get started then die off and turn it over again, then it fires right up?
Old Jul 13, 2006 | 08:05 PM
lilozzy's Avatar
lilozzy
if i dont hold the ignition very long i have to try and turn it over again and yes it will fire right on up. all this is in about a 3 second period. it used to fire up pretty fast, well faster than now
Old Jul 13, 2006 | 08:12 PM
Jugador's Avatar
Jugador
maybe the starter is wearing out over time or your battery isn't as charged as it used to be, but that doesnt sound like too big of a deal.
Old Jul 13, 2006 | 08:20 PM
65coupe88hatch
im having that same problem, i hope my starter isnt wearing out
Old Jul 13, 2006 | 08:25 PM
Jugador's Avatar
Jugador
i dont literally mean wearing out, but id imagine it becomes less effective over time. perhaps only because of the battery though
Old Jul 13, 2006 | 08:47 PM
65coupe88hatch
the other day it did die on me randomly while i turned acc. on to listen to music while i cleaned my car went to start it and nothing, charged it for few hours worked fine but i checked it and said its fine..i still think thats the cause of my problems.
Old Jul 14, 2006 | 01:57 AM
tightdogal's Avatar
tightdogal
weird. my car did it too for a while andi thought it was the battery/alternator and it was fine. so while it COULD be the starter, im still not 100% sure. ive asked across several people and they keep telling me its the battery and its not so im thinking it very well may be the starter but the problem is seeming to getting better now so i kinda stopped caring lol..
nijoma, throttle body control? really? so far this whole time i was thinking it was the starter just acting up
Old Jul 14, 2006 | 12:34 PM
lilozzy's Avatar
lilozzy
so what everyone suggest to do first? replace battery or check starter/alternator?
